93 ranger auto locking hubs reinstalling problem
hiway53recycling
Alberta canada
I just did my inner and outer front axle u-joints and I'm having a problem reinstalling the auto locking hub onto the spindle shafts. I can get it to go on to the shafts but as soon as I release the pressure from my hand the auto locking hub pops off the shaft. Is there a special way to install these auto locking hubs ? I had no problems removing them with my hand.
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Welcome to TRS :)
Disassembly pictures here: http://www.therangerstation.com/how-to/axles/automatic-to-manual-hub-conversion/
The cover is held in place by the wheel lugs, or "clips" on one or two of the lug studs
Not sure what else is "popping off" from the description
One heads up, keep wheel grease at a minimum, just lightly oil the "auto hub" section, it needs to move freely to work well, thicker grease prevents that
hiway53recycling
Alberta canada
I can't get the automatic cam back on to the shaft. Maybe I don't have the wheel bearing nut tight enough ?? I need to get my truck back on the road today.
RonD
Official TRS AI
8,370
canada
So you can't get the C-clip back on the axle to hold cam in place?
3rd and 4th picture in above link
Wheel bearing is tightened the usual way, like almost all wheel bearings, spin the hub as you tighten the nut when its tight back it off an 1/8 of a turn, then lock it
You want it to spin free but not wobble
Members online
Today's birthdays
Shran
April Truck of The Month
