Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Axles, Brakes, Wheels & Tires > Brakes
Notices
Reply
Thread Tools Display Modes
Old 08-27-2009, 05:08 PM   #1
akulczycky
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger XLT
akulczycky is on a distinguished road
Default Replacing Brake Lines...what is this, how do I remove it?
I'm a "first time" mechanic, and I am working on fixing up my '97 Ranger, starting with replacing the front and rear brake lines with stainless steel tubing (b/c I never want to do it again!).
Initial Post
http://www.therangerstation.com/foru...ad.php?t=58350
Anyhow, I've started to pull out the old line, and after an afternoon of struggling with rusted on bolts, I've managed to get to this point (Driver's Side - slow, I know, but I'm a rookie!)
First off, I don't know what it is (I'm guessing the hose, but not sure - was planning to pull it off and go to NAPA and ask the guy for "one of these"). Second, does it come off? and Third, if it does come off, how do I do it, because I think there's some clip which has now fused to the frame of the vehicle.
I saw this
http://www.therangerstation.com/foru...ad.php?t=57021
and I'm assuming what I need to do is follow the same thing, but again, I'm not entirely sure.
I did buy one of the Chilton Manuals, and I'm bidding on a shop manual on ebay, but the Chilton wasn't too much of a help.
akulczycky is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 08-27-2009, 06:27 PM   #2
martin
Vehicle Year: 1984 1991
Vehicle Make: ford
Vehicle Model: b2 explorer
martin is just really nicemartin is just really nicemartin is just really nicemartin is just really nice
Default
It's the end of the flexible hose.
martin is offline   Reply With Quote
Old 08-27-2009, 06:30 PM   #3
akulczycky
Vehicle Year: 1997
Vehicle Make: Ford
Default
Okay, now, how do I get it off...it's rusted on pretty solid, and I broke half the retaining clip off trying to remove it...any suggestions?
Old 08-27-2009, 09:49 PM   #4
Tagg
Junior Member
Tagg's Avatar
Vehicle Year: 1996 1995
Vehicle Make: Mazda Ford
Vehicle Model: B4000 LE Ranger XLT
Tagg is on a distinguished road
Default Just DID This !!!
I just purchased a 1996 Mazda B4000. The rear steel brake line was leaking above the rear axle where it connected to the rubber hose at the frame. Changed out the Steel line along the frame past the gas tank and upto the ABS pump. I purchased the parts from Advance Auto. They had the 3/16" tubing on a 25' roll. I duct taped the ends of the tubing ( to keep the dirt out ) after installing the proper fitting on it and then double flaring the tubing. Then I fed the tubing along the frame with the only connection being made at the ABS and the flex hose. I reattached the plastic mountings for the brake line along the frame. I then cutout the lines attached to the rear axle upto the wheel cylinders.
As I was pumping up and bleeding the wheel cylinders the front steel line to the left front brake caliper blew. Then, I just got hold of a cutoff grinder and did just that, Cutout all of the old steel lines from ABS pump to the front calipers and also the rubber hoses and only unbolting at the rear of the calipers. The best way to get the split clips off at the frame at the end of the rubber flex line is to use the cutoff grinder wheel and just cutoff at frame. Then taking a punch and hammer and punch out the fitting at the frame. Just need to be careful of the coil springs, Not much room to operate the 4" cutoff wheel in that space up to the frame fitting.
Replaced all lines within 4 hours by myself. Sorry for the long post, hope this helps. Its best to change everything if 1 line blows out. I want brakes when needed. Total cost for materials and parts ( steel brake lines and all 3 flex lines ) was just over $ 85.00 from Advance.
Biggest problem was using the double flare tool. They are very cheaply made , went thru 2 tools glad they are warranted. Advance also had the flat clips for the frame mounting of the hose line in stock.
Tagg is offline   Reply With Quote
Old 08-28-2009, 11:05 AM   #5
Mark_88
Mark_88's Avatar
Vehicle Year: 2007
Vehicle Make: Dordge
Vehicle Model: Care A Van
I use this vehicle for: Space travel
My credo: Love Thy Neighbor
Mark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond repute
Default
To answer the "how to remove" the clip, it's pretty easy...they usually just slip around a ring on the flex line coupling and you can usually knock them out with a hammer and screw driver...after you remove the line attachment on the inside.
If you are replacing the entire brake line from the master down, then you have less to worry about. You should, in the process, replace those lines anyways, and it's a good idea to replace the flex lines on both sides.
It is not difficult to do brake lines...I did mine complete front and back last year and the only problems I ran in to were getting the proper fittings...and getting a splicer for the rear line because I bought sections instead of a roll of brake line...just take a piece of it to the store with you to compare when you buy parts to make sure you get the right size line and the proper fittings for the lines...
The master has two lines usually, and the fittings on those are NOT the same size (from my experience)...so take those with you too...
EDIT: Oh, and you might want to invest in a good flaring tool, a line cutter, and if you are so inclined...teflon tape...(I used it on all my line fittings, but some say you don't really need it)...
__________________
Rome and my Ranger were not built in a day...
1988 Ranger 2.0 5 spd (gone)
1988 Ranger 2.3 " (gone)
1996 Ranger 2.5 (gone)
On-line manual link
http://www.therangerstation.com/foru...94#post1581294
Mark_88 is offline   Reply With Quote
Old 08-28-2009, 12:32 PM   #6
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
DO UNDERSTAND that on an '89-97 Ranger that doesn't have 4WABS
the top end of the drivers side line IS the junction block that "splits" the line coming from the master cylinder to the two front brakes.
There should be another line screwed into the "back side" (the side the clip goes on)
of that line.
On the passenger side there will ONLY be the line into the back.
Be happy it's one less line end you have to flare.
Frankly I expect to destroy the clips and you should buy new
ones to go with the new hoses.
AD
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Old 08-28-2009, 12:48 PM   #7
Mark_88
Mark_88's Avatar
Vehicle Year: 2007
Default
of that line.
AD
Yeah, now I remember...the line from the master comes down to the junction box that splits the lines to the front brakes...and you only need a short piece from the flex line to the junction...but a long line from the passenger side...IIRC I bought a one foot and a four foot lenght to go to the junction box...and a two foot from the junction to the master...with an impressive bending job that I still admire every time i open the hood
Oh, and the flex hoses should come with new clips...but I used one of those open ended pin jobbys that some people use to keep their hoods closed with those hood pins...sorta like a bobby pin, but much bigger...it worked...still works...but I haven't hit any bumps with the front end to see if it will dislodge and leave the flex hose dangerously dangling...
__________________
On-line manual link
Old 08-29-2009, 12:57 PM   #8
AllanD
Vehicle Make: Ford
Default
I specifically upgraded to the '89 style brake hose and line routing
while I was getting rid of my original "oddball" (86-02/87 calipers)
and had to buy new brake hoses anyway.
That was the first time I replaced the lines, unfortunatly it wasn't the last.
When I replaced them two years ago when I had the truck off it's frame
I replaced everything in stainless steel.
I don't expect to replace them again.
AD
__________________
Old 10-08-2009, 02:38 AM   #9
laclabb
laclabb is on a distinguished road
Default
Quote:
Initial Post
I saw this
I did buy one of the Chilton Manuals, and I'm bidding on a shop brake line kits manual on ebay, but the Chilton wasn't too much of a help.
I am also in the process of replacing my stuffs as well. I just want to know where I could get some awesome brake line kits?
laclabb is offline   Reply With Quote
Old 10-08-2009, 03:38 PM   #10
Mark_88
Mark_88's Avatar
Vehicle Year: 2007
Default
Quote:
You should be able to find all brake parts locally...they are not usually special order...unless you are doing a lift and need extended lines...but those may also be available...
__________________
On-line manual link
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Replacing excluder dust seals: My How-to stinkijeans Off-Road 4x4 Suspensions 8 05-08-2011 11:45 PM
from old 4.0 swap MrE_Powers 'Other' Engine Conversions 5 04-26-2011 08:59 PM
polymer brake lines cavallin32563 Brakes 0 06-23-2009 03:30 PM
Replacing Idler and Tensioner Pulleys - 95 4.0 Hazmat Ranger Submission Archive 0 05-09-2009 01:13 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
