Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Axles, Brakes, Wheels & Tires > Ranger Axles
Notices
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Reply
Thread Tools Display Modes
Old 08-11-2018, 12:58 PM   #1
Maiawolf
Maiawolf's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger XLT Supercab 4wd
I use this vehicle for: TBD
Maiawolf is on a distinguished road
Default Rebuilding 96 ranger front end
Learning alot about the TTB front end with lots of mistakes... Anyway I have a bent right side axle Beam (got to figure that out) but I found the bolts are missing for the upper and lower radius arm and coil.. (messy garage)
any suggestions out side the local junk yard? and while your thunking on that any ideas on the best way to straighten a slightly twisted axle beem?
thanks
Maiawolf is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 08-11-2018, 01:31 PM   #2
Denisefwd93
Denisefwd93's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger XLT 4X4
I use this vehicle for: daily driver maybe off road someday
Denisefwd93 has a spectacular aura aboutDenisefwd93 has a spectacular aura aboutDenisefwd93 has a spectacular aura about
Default
We basically rebuilt my four-wheel drive 93 front end ttb. Seems very simple, although the hardware is very large and I physically needed help with that stuff.
you can probably find the whole front assembly easier than getting the radius arm. You just want to make sure it has the same ratio your front end has.
__________________
"old broad with a truck" 3rd Generation family HVAC business owner (retired)
http://www.therangerstation.com/foru...d.php?t=176465
Denisefwd93 is offline   Reply With Quote
Old 08-11-2018, 06:32 PM   #3
cstarbard
Vehicle Year: 1996
Vehicle Make: Ford
I use this vehicle for: Transporting rubber ducks
My credo: It do like it be
cstarbard is on a distinguished road
Default
How badly bent is the axle beam? Is it twisted? Dented? Just not sure what you meant by bent
You might be able to coerce one back to normal with a torch and some patience, but the heat could de-temper the beam and isn't the best idea considering what is at risk if the beam failed, at least in my opinion
In terms of other ways to straighten it, you might be able to use jacks and presses, but for all the labor and risk involved with that it would be better to just get a replacement beam that you can see is undamaged and true
By right side you mean passenger side, correct? If so you shouldn't have to buy the whole front assembly, with both beams. No need to change the driver side beam unless you have to or that is the side you mean is bent, getting the differential on and off, gasketed, lined up, is really quite a pain, finding a beam with your ratio may not be super easy either depending on the ratio, the cross bolt holding the diff in place will not come off with radius arm in place also, something to keep in mind if thats actually the side you need to fix
Like Denise said it is simple enough to work on just very heavy and awkward. You may want to check that your radius arm hasnt become twisted or damaged as well
Honestly, removing the axle beam in a junkyard would be easier to do in a sense, just remove with the radius arm attached, and now you would get a good beam, radius arm, and your missing hardware (yikes!)
cstarbard is offline   Reply With Quote
Old 08-11-2018, 06:37 PM   #4
Denisefwd93
Vehicle Year: 1993
Vehicle Make: Ford
Default
Think I'd just have a yard cut the front frame off a 4wd truck with the right ratio ttb, probably take them all of 10 minutes
__________________
Old 08-11-2018, 06:39 PM   #5
cstarbard
Vehicle Year: 1996
Vehicle Make: Ford
Default
I suppose that's true, maybe it would be cheaper?
If so as long as you have a way to get it spare parts arent a bad thing
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1986 ford ranger 2.3 need info on rebuilding my head unrevealeddrive 4-Cylinder (2000 & Older) 2 07-02-2015 08:48 AM
Planning on rebuilding my 89 ranger motor riss6270 General Discussions 20 10-03-2012 12:49 PM
Need help rebuilding '87 2.3 treblot 4-Cylinder (2000 & Older) 4 03-10-2009 09:16 AM
rebuilding a 3.0 from a taurus for my ranger need info. 93worktruck 3.0 Liter Forum 7 06-04-2008 11:05 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
