Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
Notices
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 08-13-2018, 04:39 PM   #11
Junk Collector
Shran's Avatar
Shran has a spectacular aura aboutShran has a spectacular aura aboutShran has a spectacular aura about
Default
The YJ is a good platform to build off of. Lots of flat sheet metal that's easy to repair if necessary, tons of aftermarket support. Decent drivetrain options. Some YJs have carbureted engines, though, plus relatively small axles and leaf springs all around.
I wouldn't build another 1st gen Ranger wheeler if I had the choice. It would have to be a 2nd gen or newer.
__________________
1986 Ranger XL 4x4, 302, NP435/205, HP D44, RCV shafts, 8.8 Lock-rite/lsd, 4.10 gears, 35" Kevlar MT/R --- Build Thread
1988 Ranger XL 2.3/M5OD 4x4 daily driver
1986 F150 4x2 302/T18 toy
2007 F250 4x4 V10
1992 Explorer 4 door expedition rig
1994 Explorer 2 door future offroad racer maybe?
1989 Ranger 4x4 4.0/M5OD/D35/8.8 swapped
Shran is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 08-13-2018, 06:12 PM   #12
85_Ranger4x4
December 2013 OTOTM
85_Ranger4x4's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: A weapon of massive consumption.
85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute85_Ranger4x4 has a reputation beyond repute
Default
If you do the YJ gotta do the Jurassic Park paint scheme...
If you are wanting to get into building Ranger parts a newer one of those would be good for mock-up and to showcase said parts.
__________________
1985 Ford Ranger Custom, 4x4, PA 3" BL, 5.0HO, M5R2, Twin-Stick NP205, 31 spline T/L 8.8 w/ disc brakes.
Check out my Build Thread
Check out my NAIAS Ranger Trip
"I have not failed. I have just found 10,000 ways that won't work." - Thomas A. Edison.
85_Ranger4x4 is offline   Reply With Quote
Old 08-15-2018, 10:01 AM   #13
Mightyfordranger
Mightyfordranger's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: broncoii
I use this vehicle for: wrenching
Mightyfordranger will become famous soon enoughMightyfordranger will become famous soon enough
Default
[QUOTE=Jim Oaks;1633598]I'm going to throw my $.02 in to the change bucket.
I know you want to build bumpers for Ford Rangers. If you're going to attend a gathering where you know there's going to be a lot of Ranger owners, then why not show off your work?? Consider this? QUOTE]
agreed Jim I should go with a newer truck. This other ranger that I have would need a new engine and lots of other work. The new 4.0s make good power enough to turns 33s, and if I pick up one of those trucks it will save a lot of time. As well as about 3k on building a new small block.
__________________
Doin the three pedal tango...
Mightyfordranger is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
New B2 Build Ryannn Ford Bronco II's 1 08-26-2013 11:34 PM
1994 ranger build "Lizzy" (Slow build thread) Funnyman141 1983-2011 Off-Road & 4x4 Ford Ranger's 33 06-29-2012 03:12 AM
93 budget build! First build actually. 93 Ohio Ranger 1983-2011 Off-Road & 4x4 Ford Ranger's 85 10-02-2011 10:00 PM
85 Mad Max Build TheStig88 1983-2011 Off-Road & 4x4 Ford Ranger's 31 06-09-2011 07:08 AM
Need Some Help With My Build crawfost 2WD Lifted / Edge / Prerunner Suspensions 3 02-14-2011 10:04 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
