93 Ranger intermettent ignition problems
Wahoojim
I have a 93 Ranger with a 2.3L - the dual coil setup. Starts up and runs fine but after a while as I am driving all of a sudden it acts like it jumps time and looses power like it has dropped 2 cylinders and it starts smoking sometimes it starts back running fine. I can park it and wait and it starts up fine. So it seems to be heat sensitive. I have replaced the plugs and wires but no luck. I am thinking it could be a coil pack??
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
Sounds like a coil. Could be a bad cat but more likely a coil.
Earl43P
38
Farmington, Pa
Ford F250 4WD
3.0
Sounds like a bad ICM to me. If it were a coil, it'd have to be that both are bad. Only one is used for starting, then both after it's running, IIRC.
ICM (ignition control modules) heat up and fail.
If you swap the coils positions and it won't start afterward, I'd agree with 2 bad coilpacks, but it's not likely.
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Whenever I hear about backfiring on an EEC-IV managed ford I think fuel filter.
To be backfiring it is sparking.
AD
Staff online
Shran
April Truck of The Month
