Wanting to fab some things...
TorontoEdge
So I'm looking to build a relationship with a metal fab place as I want to make some skid plates, nerf bars and a prerunner bumper for my '02.
I'm trying to find a small shop in Durham (or GTA, pref. East of Toronto).
:icon_welder:
I'm wiring up my garage for 220 and buying a welder but I still need someone with a mandrel bender and a means to cut (plasma or water jet) and bend some metal plates.
fordnut71
1994
ford
ford
Try pro street in Whitby on wentworth. They might be able to help
Sent from my Passport using Tapatalk
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
You don't need a mandrel bender unless the inside of the tube HAS to stay the same I.D. If you're bending tube for bumpers you can get away with a pipe bender. If you are doing cages then a proper tube bender such as a pro-tools 105 or jd^2 or jmr brand is needed. A 4.5" grinder will cut plate and a 12-ton press can bend plate up to 1/4" x 10" if the radius isn't too sharp.
TorontoEdge
thanks guy, i just put in a 220v circuit in my garage and picked up an old lincoln 225/125 ac/dc stick welder. Building a metal workbench to practice welding, it's been a long time since I welded.
Staff online
Today's birthdays
Shran
April Truck of The Month
