Can you remove 93 4.0 while leaving A/C connected?
Vincenthdfan
2
Olympia, Washington
Hey all,
I was just getting ready to pull my upper & lower intake manifolds for new gaskets and rocker arm covers for new gaskets on my 93 4.0.
While in there I was going to change my rockers and pushrods because they have the usual ticking noise to them.
Then....as luck would have it, a guy was selling a 97 4.0 OHV with only 120,000 on the clock for dirt, dirt cheap...basically "I need this outta my shop to make room" cheap!!
He was in the middle of doing a 5.0 swap into his 2 wheel drive 97 Ranger.
He even threw in the 5 speed with the deal for no extra!
So now I'm at a crossroads....
Do I just proceed with my re-gasketing and rocker replacement on my '93 motor, or go to the trouble of swapping over all the external parts and changing entire engines (actually the cheaper route, believe it or not)?
If I do pull my 93 motor out, I cant for the life of me see how it will clear the still connected air conditioning lines that are routed IN FRONT of the engine (thanks Ford!!)
I really don't want to disconnect the lines because it's an R-12 system and it still works just fine, if you can believe that??!!
So tell me, will I be able to clear it?
I know I will have to pull radiator, fan & fan clutch, etc to make room....but I don't want to get 3/4 of the way through removal and find out it wont clear the lines....
Whats the consensus please?
Thanks!
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
It can be done. It is the harder way to do it, but it can be done.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
And most likely the hoses will start to leak after you've moved them around anyhow. it's time, take it apart do it right.
Elutheros
129
Central Texas
Engine Type
V8
5.0
2WD / 4WD
I did just that on my 1994--so yes it can be done.
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
I once removed all the ac related stuff without losing pressure. It took me about 13 hours.
Dirtman
Former Middleweight Moss Fighting Champion
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
You must have been REEEEAAAALLLY desperate to save that 75 bucks. :icon_rofl:
alwaysFlOoReD
Forum Staff Member
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
It was a bet. I won. I think. Maybe.
Dirtman
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
Unless the person you bet had to roof an entire condo complex by themselves in August for loosing the bet.... no... no... you lost.
Staff online
Today's birthdays
Shran
April Truck of The Month
