Disk brakes
joey74
18
Vincent Ohio
Will rear disk off a crown Vic fit a ford explorer? Thanks joey!
The wheel bolt patterns are the same, but the rotor and pad numbers are different, so probably not.
I get that you are trying to use parts mostly on hand already, but I will again pose the question, if you are using an Explorer rear, why not use Explorer brakes.
joey74
18
Vincent Ohio
OK thanks will look for explorer brakes!
Denisefwd93
74
South East PA
I think there is a discussion on using Explorer rear brakes disc backing plate caliper and bolting them onto a Ford Ranger 8.8 rear
It doesn't work, unless you have F4 L2. The 28-spline tubes are narrower at the ends, and the bolt pattern for the baking plates/caliper brackets is wrong.
At least in the year range of the OP's truck. It may work with some of the later ones.
Mustang brakes on a 7.5 works, but it isn't a straight bolt-on.
