1987 ranger
TNT6751
Elkins WV
Ford ranger
2.9l
does anyone know if a 1994 explorers front and rear axles are plug and play with the 1987 rangers mounts? any advice will be helpful
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Front yes, rear no. Rangers and BII are spring over axle and have the shock tabs welded to the tubes, Explorer is spring under axle, so the spring pads have to be moved, and the Explorer's shock tabs are part of the lower plate that bolts under the spring to hold the axle in, so they have to be added to the tube to use an Explorer axle.
Staff online
Today's birthdays
Shran
April Truck of The Month
