All of a sudden it's at 1500 RPM
celticpiping
Maine
My Manual 5-speed 2003 ext cab 3.0, all of a sudden over the last day, is idling at 1.5K rpms, and I'm noticing that when shifting, it feels like a sort of...clunkiness happens... meaning, more shifting noise than previously..
I know that's not tons to go on, but any thoughts?
I peeked under the hood, but saw nothing amiss(that I could see)
Thanks lads,
Rich
Rearanger
23
Southeast USA
My high RPMs at shifting was solved by cleaning the TPS connector contacts. Signal from the TPS to PCM was not happening fast enough.
Understand that the RPM will stay higher when you're coasting in neutral as the speed sensor tells PCM to give higher RPM.
celticpiping
Maine
Thanks.
I thought I had subscribed to the thread, so didn;t see the reply..
cheers,
Rich
rangerenthiusiast
Hudson Valley, NY
If that doesn’t help, it could be a vacuum leak. Seems like these trucks have a lot of problems with racing idle (I know mine did). Here’s a thread of mine with some other possibilities too (IAC, etc):
https://therangerstation.com/forums/showthread.php?t=176685
Hope yours turns out to be an easy fix! :icon_thumby:
celticpiping
Maine
