1989 7.5 to 2001 8.8 rear end swap?
KlownChapel
West Fargo, ND
2.3L
Hello everyone,
I have a 1989 2.3L Ranger and I want to update the rear end with disc brakes and a limited slip diff. I'm wondering if I get a rear end of an 01 Explorer if it would bolt directly in. I know that it's a slightly larger axel and that the driveshaft/pinion flange would have to be swapped but I need to now if it will bolt in correctly.
Please help thanks.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The Explorer axle is not bolt in. Ranger axles are spring-over, the Explorer was spring-under, so you need a flip kit.
Also the Explorer shock mounts are part of the lower spring plates, so shock tabs will need to be added.
Unless of course you are looking to drop the rear about 4 inches.
4x4junkie
Forum Staff Member
584
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
I suspect this may be the case since he has a "Low Rangers" road sign as his avatar (it should drop it closer to 5½" as the thickness of the leaf spring plays into it as well).
The Ex axle will bolt up, though I can't say whether the pinion angle will be correct or not. It should not be so far off that you can't correct it with axle wedge shims.
Welcome to TRS. :beer:
Staff online
Today's birthdays
Mudtruggy
May Truck of The Month
