Pilot bushing removal
v-8power
31
Huntington, In.
Hey guys anyone here know if using grease to remove a pilot bushing really works? I heard it about 20 years ago but i have never tried it. Thanks for any imput.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
I have done it several times. Sometimes it works and other times it doesn't. Obviously you are asking about it so you know how it works.
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
it works more often than not though . i have only had 2 that wouldn't come out that way.
MAKG
19
California central coast
But it's unnecessary for most RBVs, as the pilot bearing (not bushing) is in the flywheel. You just remove the flywheel and tap it out with a socket.
v-8power
31
Huntington, In.
It's in the end of the crank on the engine i am working on.
Mutant Pony
9
Hersey, Mi
2300
I just resently pulled apart a 4.0l Ranger with tranny problems to find some genius put the pilot bearing in the crank. We used the Grease/spline liner trick the get the bearing out to install it in the flywheel. A failed bearing will probably not be removed this way. That is when a die grinder becomes handy.
Only the cologne engines have the pilot in the flywheel.
Kirby N.
March Truck of The Month
