Which rear end
Dangerrangers
Ohio
94 and 04
4.0 s
Do it right the first time !!!!!!!!!!
I know someone can answer my question so it goes . I have just bought another 94 ranger ,ext cab ,4.0 , stick with a 373 posi ,I know from the door codes . So are these the torsion rear ends or something else? Thanks
( Edit ) .Is it possible this truck has a traction lock instead of a torsion ¿ . Someone must know ,I can't get an answer from anyone at the stealership because they don't seem to know which is strange seeing how they are suppose to be the experts. Thanks
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,094
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
I'm not absolutely sure, I believe the TORSEN wasn't available until sometime in the 2000's
Sent from my XT1032 using Tapatalk
scotts90ranger
RBV's on Boost
4,370
Dayton Oregon
Engine Type
2.3 (4 Cylinder)
2.3 Turbo
2WD / 4WD
35"
It is a clutch based limited slip, and being a 4.0L it will have a 28 spline 8.8 rear axle.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Ok, so here is the deal.
1) It is a dealership, not a stealership. I wouldn't help you if you were being a dick either.
2) There is no such thing as a torsion rear end. Torsion, in this context, mostly refers to a torsion bar, which is a type of spring that I have only ever seen used on the front of a vehicle. They were used on 4x4 Rangers from 98 up.
3) You are thinking of a TORSEN rear end, which was only on the FX4 level 2 from about 2002 to 2006.
4) The guys are the dealership are the experts. However generally working in a dealership you won't see much of anything over 6 years old, and almost nothing over 10 years. Your truck is 22, it can legally drink. When Ford makes between 10 and 12 models a year, and changes things between all of them, and then changes stuff again every 4 to 5 years, well you just can't expect them to know every detail of every vehicle. Add to that the fact that Ford only makes build sheet data available to the parts departments fro
m 97 on up, and even with the VIN they wouldn't have been able to look it up for you.
I worked at a dealership for 6 years, we had 7 senior master techs in the shop, not including myself, and a few other guys who had been with Ford for many years, just never did the cert work, and a number of sales people who had been with Ford for decades. One day we got an FX4 L2 Ranger in with axle issues and I was the ONLY person in the whole building who knew what was special about that diff.
5) Scott is spot on with the details he gave you.
6) We know these things about Rangers, not because we are dealership personnel but because we are Ranger enthusiasts.
Dangerrangers
Ohio
94 and 04
4.0 s
The only reason I called it a stealership was back in the late 70s I worked at one of the biggest Chrysler dealerships and they told us at the service meeting ,in a round about way , to rip off as many people as we could by replacing parts that weren't really needed. So being the kind of person that I am I told them to take their job and put it where the sun don't shine. That has left a really bad taste in my mouth and sometimes I feel like they are all kind of crooked . End of rant.
OK torsen ,I don't always correct Tapatalk.
cbxer55
767
Midwest City, Oklahoma
3.0
While on the subject of axles, how can I find out what type my 98 SPORT has? I wish to put a different cover on it, as I did my Lightning. A lot of aftermarket covers have a drain plug and a fill plug, eliminating the need to pop the cover every time you want to change the oil.
My Lightning has a 9.75 12 bolt, and I put a TA cover on it. The Ranger has a 10 bolt, just not sure what type, and if a cover is available. It looks like the 8.8 covers that are available in this sites Parts Store.
http://www.jamesoaksenterprises.com/index.php?main_page=product_info&cPath=109_110&products_id=275
alwaysFlOoReD
Forum Staff Member
5,094
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
cbxer55
767
3.0
It's probably an 8.8. check the door tag or axle tag to be sure. There's tag decoders in the tech section if needed.
I looked at the door sticker and saw goobletygook. I'll check it again tomorrow. Suspect it is an 8.8 with 3.55 gearing. And with the low profile 255/60-15 tires, it runs more like 3.73's. ;-)
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Got a picture? A pic of the cover is always helpful.
cbxer55
767
3.0
I'll see if I can get one tomorrow. Truck is backed into the garage, doing the intermittent "crank but no start thing" again. GRRRRR!!!!!!:annoyed:
Mac
183
C. Wisconsin
2000
199
4.0
To OP, See that it has a 4.0 so that makes it a 8.8.
cbxer55
767
3.0
Nope. Door code is 86. That's an Open 7.5 with 3.73 gears.
Just found out that TA makes covers for both the 7.5 and the 8.8. They are awesome covers ,with both a fill and drain plug. Here's my Lightning's rear end with TA cover, QA-1 shocks, JLP Long Bars and BroncoBeater Pan Hard bar.
Here's the ink to TA Performance.
http://www.taperformance.com/products.asp?cat=52
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,598
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
Fairly decent price, too. Is that cover aluminum?
alwaysFlOoReD
Forum Staff Member
5,094
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
From TA site;
Specifically designed to add support to the bearing caps under severe loads and acceleration, these girdles substantially strengthen the rear end. They also add fluid capacity, which helps to lower the fluid temperature. Comes with drain and fill plugs for easy maintenance.
All TA Girdles are made of 356 aircraft grade aluminum, heat treated to T6 specifications, each cover is then stress relieved.
All Girdles incorporate a Fill Port and a Drain Port for ease of servicing.
All Girdles incorporate 2 load bolts with swivel "feet" for supporting the bearing caps.
All Girdles increase fluid capacity approx. 1/2 pint.
All Girdles show a decrease in operating temperature, average of 15 degrees.
Weighs about 7.5 lbs.
Improves Undercarriage Appearance.
cbxer55
767
3.0
Yes, aluminum and fairly thick at that. The flange is way thicker than the stock sheet metal piece. The kit includes longer allen head bolts. I need to measure how far my rear sway bar is from the stock cover. On Lightnngs, the TA cover hits aftermarket Hellwig bars, like the one on my Ranger. I'm not going to lose the rear sway bar for a fancy differential cover.
Staff online
Shran
April Truck of The Month
