Denisefwd93
- May 20, 2015
- Reaction score
- 74
- Location
- South East PA
- Make / Model
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- stock, may get leveling springs in front "somday"
- Tire Size
- 235
Trying to track down this wobble shake on the back end at 40-65 mph.
Truck it is up on stands.
The back right side wheel is off,
there are no balance weights on the brake drum. the axle flange has a very very slight wobble hardly even perceptible guessing 1/16" or less.
The axle bearing moves not even a 1/32" an inch up and down but does move.
End play is very snug, I would say under 3/16"
Weather permitting, tomorrow we will check the left side and then both sides running in gear without the brake drums.
