GMitchell
- Apr 26, 2014
- Reaction score
- 0
- Make / Model
- Ford
I'm new here and this is my first post. I replaced the clutch, pressure plate, flywheel, and slave cylinder on my 1997 Ranger (250,000 + miles). Trans wouldn't disengage while engine is running, although I bled the master and slave cylinders. I thought there might be something wrong with the clutch plate, so I decided to drop the trans. again. All bolts and connections are loose but I can't pull or force the trans away from the block for anything. Any ideas? ANY help would be appreciated!
