Best clutch for 87 ranger 4x4 high rider
TDumas
What is best clutch
Sent from my XT1635-01 using Tapatalk
scotts90ranger
RBV's on Boost
4,368
Dayton Oregon
Engine Type
2.3 (4 Cylinder)
2.3 Turbo
2WD / 4WD
35"
I believe your best cheap clutch upgrade is going to be a 4.0L clutch swap, there should be lots of posts about it along with maybe a tech library entry... from memory (never done one) you need a 4.0L clutch and flywheel and maybe a different starter, gains a lot of surface area...
Short of that you're stuck with something more expensive like what I had to do on my 2.3L (4.0L clutch swap doesn't work on the 2.3L), I bought a stock replacement Centerforce friction disc and their pressure plate with the weights on the fingers, it's been amazing and I recommend it a lot but there's no kit that I know of with those parts and it was over $300 for the parts where the 4.0L clutch could be done for around 2/3 of that...
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
4.0 clutch swap requires a clutch kit, flywheel, 4.0 manual starter and block plate.
A lot of people try to skip the block plate, it is a 100% must have, as it locates the starter.
If you have a 2.9 and want to upgrade that is the best bet. I personally prefer NAPA clutch kits, they are made by LUK which is the OE manufacturer for Ford. Good quality parts.
TIGGER
Beaverton, Oregon
2.9
I’m using the original 2.9 block plate on my 4.0 clutch conversion. All I had to do was to file out the opening ever so slightly for the starter to fit. I’ve had no issues for 15 years and 80k. Still going strong. Best upgrade I ever did to my truck.
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
I did the same. The hole only needs to be widened by couple millimeters (not so much you can't do it with a large half-round file if you go at it carefully and evenly). Been maybe 12 years now since I did mine.
I can see how not having the block plate at all would cause issues though.
And ×2 on LuK clutches. I've seen enough issues with other brands to warrant avoiding them (squealing probably being the most common).
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I saw a thread a while ago (a few years now) where someone did the 4.0 clutch to a 2.9 without doing anything with the block plate and really buggered up their starter from it being in too close.
But yes, if you have the skill you could just file it out a bit, the difference is minimal. I just don't like to assume people have certain skills. The people who have them know, and will use them. The people who don't often don't know and will screw things up trying.
Staff online
Members online
Shran
April Truck of The Month
