Manual Transmission stuck after clutch change
BudgetB3000
Pullman, WA
Mazda
I just finished doing the clutch job on my truck, I got the transmission and everything put together and all buttoned up, and now the shifter is stuck and the clutch pedal has no pressure. Is it possible that the slave cylinder I purchased was faulty from the factory? I wouldn't think the system needed to be bled again as all I did was remove the quick detach when I did the clutch. The shifter will not budge whatsoever and whether the car is on or off makes no difference.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Did you bleed it at all after replacing the slave?
Craig0320
225
Mississppi
Engine Type
V8
5.0
2WD / 4WD
Break it right the first time. Fix it better the next time.
BudgetB3000
Pullman, WA
Mazda
I was under the impression that the slave I purchased was pre-bled. I'll bleed again and report back.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Pump the pedal about 25 times, then try bleeding it. Even the pre-bled ones need pumped up.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
assuming, you took the shifter out, did you put it back properly? I know it's easy to go wrong on this...
BudgetB3000
Pullman, WA
Mazda
I did take a peek inside to make sure it was in neutral, and I believe it is
BudgetB3000
Pullman, WA
Mazda
I used a vacuum bleeder to bleed the truck from the reservoir today. 6 or 7 HUGE bubbles came out and I figured I would be good to go but the shifter still wont get in to gear. Ill try again tomorrow.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The two pins in the hole (lower ones) need to be centered and even.
You would have a hard time putting the shifter back in with the trans in gear. Not impossible, just difficult.
BudgetB3000
Pullman, WA
Mazda
yep I double checked it today and the trans is in neutral. Now I just need to bleed the system well tomorrow and based on the progress I made today I think I should be good to go.
Denisefwd93
74
South East PA
Engine Type
4.0
2WD / 4WD
I don't know how it happens but it took me two tries to get the shifter stick into the transmission and it would not move. the third time was the charm and it shifted in all the gears
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
If I have to take the lower nub out, which I try to avoid, I am meticulous with not knocking it into gear while that is out, even though I know how to fix it.
Tuesday night I was taking the top off my parts trans so I could inspect the 2nd gear syncro and see which one I need, and I hit a fork knocking it into gear.
Members online
Today's birthdays
Shran
April Truck of The Month
