Also just a used car buyers tip
All fuel injection computers have a Clear flooded engine routine
Turn key ON, starts up computer
Press gas pedal down to the floor, and hold it down, turns OFF fuel injectors
Turn key to START
Engine should just crank and not start, no fuel, until you release gas pedal from WOT(wide open throttle)
Thats Clear flooded engine routine, allows you to dry out a Flooded Engine
I use it every morning on my high mile 1994(obd1) 4.0l to pump oil thru the engine before it starts, so no dry starts
But it can be used by car buyers with the knowledge of it to get a few dollars off a used car price.
A NO START is not a good sign when buying a used vehicle....................
Knowledge is power, and it is also a test, you are testing Computer, TPS(throttle position sensor), throttle cable, if its stretch test won't work because no WOT, and fuel injectors for leaks or shorts to ground, engine would fire if an injector was leaking
But if seller thinks there was something wrong and wants to knock down the price a bit, no skin off your nose.
OK so can't dress it up as a test, its dishonest, lol.
But at least you know about it now, so when you sell a used car and it doesn't start when buyer tries it, you will know why
