permanent pressure gauge
mikie
clayton, idaho
ford
Engine Type
2.9 V6
2WD / 4WD
I want to install a permanent fuel pressure gauge but I cant find the right thread adapter to attach my gauge to the fuel rail. Anyone know what threads are on the current schrader valve. 88 ranger 2.9
IIBRONCOS
10
AZ
2.9
I am also awaiting the answer..
Paulos
210
North Carolina
1987 STX
Ranger
Engine Type
2.9 V6
2WD / 4WD
From what I could find, a standard Schrader valve thread is 0.305-32. you can find a tap and die here on eBay, or just the tap.
dirtymike
112
knoxville TN
Ranger lwb
Engine Type
2.9 V6
2WD / 4WD
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
Why do you need a fuel gauge in the dash
RonD
Official TRS AI
TRS Technical Advisor
8,298
canada
Look at truck tire extension air valves
Google: tire extension valve rubber
Semi-truck tires run 60-110psi so they can handle the pressure
If you are looking for a permanent pressure gauge I would go electric, make an adapter for sensor hook up at fuel filter then run a wire into the cab for the gauge.
Having the actual 30-70psi fuel(gasoline) pressure INSIDE THE CAB for long periods just doesn't seem like a good idea to me :)
And tapping fuel pressure at the test valve for longer periods also seems like a bad idea, even a small leak could lead to a very very bad result
Viking Funeral..............on the highway, be fun to watch, but not from the inside
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Banner 2012-2015
Ugly Truck of Month
4,667
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
mikie
clayton, idaho
ford
Engine Type
2.9 V6
2WD / 4WD
Done. I used a 1/16 pipe (NPT) to 1/8 pipe (NPT) adapter. Fuel gauge screwed right in, works great no leaks. Where in my post did someone confuse the spelling of "fuel rail" with "dash"?
RonD
Official TRS AI
8,298
canada
The word "permanent" would read like an "in the cab" gauge, otherwise what would be the point
Having a full time pressure gauge under the hood can only be observed when hood is open, and once you have read that pressure there is no benefit to reading it again unless there is an engine problem.
If there was an engine problem then you use the gauge until problem is solved then remove it.
Watching fuel pressure under load(driving) would be the only reason to add a "permanent" pressure gauge as far as I can see
Like an oil pressure gauge, doesn't do much good unless there is some way to monitor it while driving, can be a gauge, or an idiot light in that case, but an oil pressure gauge only under the hood wouldn't really be helpful except during first starts or problems
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,667
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
ron.
this is an extremely rare case of disagree.
your merits are great, but oil and fuel psi......(which most new cars is displayed on your phone or scanner a boon of can-bus for sure)......on older rigs is priceless for tuning and trouble shooting. i can determine a volume test is necessary or an fpr is sticky by watching my vdo's fluctuations and shit like that.
..oil pressure surge and fall off is another.
a direct mechanical gauge will read far more accurate then the standard electrics... knew one of my blocks was cracked and got it out of service before i broke another 302 in half before a long trip.
RonD
Official TRS AI
8,298
canada
I agree, but don't see the need of a permanent fuel pressure gauge in the engine bay on a street used vehicle, its something you use when there is a problem to test pressure then remove it.
I personally don't think good mechanical oil pressure gauges work any better than good electric oil pressure gauges.
Yes, electrical have do have more "parts" that can fail, and in that respect mechanical would be more reliable long term.
But running a pressurize line into the cab can also have its drawbacks, lol, with oil its just messy, with gasoline at 30-60psi pressure it can be down right dangerous
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,667
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
i was referring to a short solid temporary gauge for oil pressure..
the typical electric gauges vary greatly with wiring and ground conditions and temperature...winter time especially if salt water gets involved which has seperate issues...
you really have to wire them solidly. but for the most part they are way more then good enough. with whats on my vehicle now if you pulled power off the block it would variate with brake lights or blinkers...i have a new system sitting...some day it will find its way in that pos...
of course the electric gauges can be much better then the particular mechanical gauge i refer to, you will pay some serious coin for it as well...and like i said, it is only as good as its installation. but super fine digital definitely wins.
fuel pressure is always nice. newer vehicles are all wired for it...electrically of course...
my systems are gauged for delta....of course i run an array of fuels and have unique fuel issues...and with a diesel it is prudent because your one trip to the pump away from having a gel blob....but even with a good ol gasoline 302 it was nice to have. you can see when its filter time.
mikie
clayton, idaho
ford
Engine Type
2.9 V6
2WD / 4WD
The key words in the above posts are "when you have a problem". The truck is 30 years old and I WILL have a problem and it more than likely wont be in an auto parts store parking lot.
dirtymike
112
knoxville TN
Ranger lwb
Engine Type
2.9 V6
2WD / 4WD
1 inch spacers
P23575R15
Staff online
Members online
Today's birthdays
Kirby N.
March Truck of The Month
