helppp, 89 bronco 2 problem!
shnmarie92
ford
I've had this problem for some time now. As the engine heats, the motor boggs down and WILL NOT go any faster then 25-30 miles per hour. I live in FL, so it happens during the day ALOT. very rarely does it happen at night, its cooler at night. i've replacerd the tfi module and the cats are GONEEE. no cats, its not the motor overheating the gauge is fine. maybe a sensor of some kind? tell me what you think.
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
Check your fuel pressure when it 'boggs down'
Could be a bad FPR or an overheating fuel pump.
shnmarie92
ford
fuel tank has been cleaned out, fuel filter and pump has been changed
necessaryevil
salem,or.
ford
2.9
start looking at the "air charge temp sensor" or one of the "coolant temp sensors" one is a one wire that runs the temp gauge and the other is a two wire that runs the computer. the air charge sensor is on the upper half of the intake manifold in the center runner about half way down. and the coolant temp sensor is in the top of the thermostat housing(its where the top radiator hose meets with the engine)
jhammel85
Guest
Agreed! Have a look at the O2 Sensor too:icon_thumby:
shnmarie92
ford
Spowerback
Banned
--- Banned ---
California
FORD
v6 4.0L /
x2 bad o2 sensor and clean all sensor too
I had this probleme the last week on my ford ranger I have change 02 sensor
my computer not detect
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I'm with the O2 crowd. That's what mine used to do with the bad O2.
pwrranger88
2
rhode island
4.0,2.3
it most likely wont be the coolant temp sensor if it where it would be hard to start once warmed up and it would be running very rich.
Members online
Today's birthdays
Kirby N.
March Truck of The Month
