2.9 JBA Headers, 2 sets EGR and Non EGR
rngrracing96
55
NH
2.9 EFI
33x10.5x15
Sold.
Sent from my SM-G950U using Tapatalk
tx_pwp5
Austin, TX
4 inches
31x10.50
More auto shenanagans on instagram @waterloocustomworks
headers
These still available? I've got an 87 supercab so making sure parts will fit is always a pain. I'll have to look at my current headers but I'm in the market since my entire exhaust needs to be replaced.
rngrracing96
55
NH
2.9 EFI
33x10.5x15
They are still available. Double check your driversside head for an ERG tube.
tx_pwp5
Austin, TX
4 inches
31x10.50
Just saw your message. I'll check today. Would the Y pipe work with the EGR headers if I need those? My exhaust is toast so I'm just going to redo it all at once before it goes in for inspection. I had to convince the guy to let me slide last year and now it's worse.
An 87 2.9 will have EGR.
There is also different Y-pipe to cat flanges for EGR and non-EGR.
rngrracing96
55
NH
2.9 EFI
33x10.5x15
^ Correct. The headers should bolt up to stock ypipe
madtom421
On the 88 up headers where does the alt bracket bolt to?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Probably still bolts to the block and cylinder head like it always did.
rngrracing96
55
NH
2.9 EFI
33x10.5x15
I am unsure about the alternator. I never had the 88 headers on my truck so I couldnt say.
However as stated above, i dont think it would be an issue.
madtom421
I never realized that was bolted to the block. It looks like part of the manifold when everythings all rusty
Yeah, I have remove the alt bracket, and passenger side exhaust manifold/header from my 2.9s many times. That bracket doesn't bolt to the exhaust at all.
rngrracing96
55
NH
2.9 EFI
33x10.5x15
Bump, price dropped $50 each
tx_pwp5
Austin, TX
4 inches
31x10.50
I'll take the ones for the 87. PM sent
tx_pwp5
Austin, TX
4 inches
31x10.50
Bump- PM Sent
Kirby N.
March Truck of The Month
