SOLVED: Cat Red Hot - Carpet Melted/Charred
gnarlybus
AZ
My buddy is giving me his 89 Bronco II XLT 2.9L 2WD. He has an issue with the catalytic converter getting really hot and melting the carpet (then charring it) inside.
At first I thought, ok no problem, I'll replace the cat and be good to go. But now I'm concerned that after replacing it nothing will change.
There is no lack of power or audible miss in the engine. He drove it 65 on the freeway and had to keep pulling over every 20 mins because it would get so hot, but it had power.
I have to drive 5 hours to go get it and bring it home so I'm trying to be prepared. I figure I'll warm it up and check each cylinder for spark and make sure they're firing. Then I'll get underneath with a laser thermometer and check the temps before and after the cats. Anything else I could do to be prepared?
I don't want to spend the cash just to have the cat get toasty again.
Uncle Gump
Token Old Guy
TRS Event Staff
13,435
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
2WD / 4WD
Lead follow or get out of my way
If the converter is getting that hot... it is a fuel issue. The thing is running to rich.
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
^^^Agreed. Check fuel pressure regulator for gas smell in the vacuum line. Should change o2 sensor too.
gnarlybus
AZ
Is there only the upstream o2 sensor or are there 2 on the 89?
Are the Haynes or Chilton's manual worth getting or should I pay extra for the official one?
alwaysFlOoReD
Forum Staff Member
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
1 upstream. Make sure there are no holes or leaks ahead of the cat.
snoranger
Professional money waster
TRS Event Staff
RBV's on Boost
ASE Certified Tech
GMRS Radio License
13,625
Jackson, NJ
'79,'94,'02,'23
All Fords
Engine Type
2.3 EcoBoost
2WD / 4WD
I didn't ask for your life story, just answer the question!
While you're checking pre and post cat temps, check the manifold temp at each cylinder. That can lead you to a misfiring cylinder.
gnarlybus
AZ
Will do. I'm thinking that if I can't figure it out, I'll disconnect the cat and drive it home loud.
Sent from my LG-US996 using Tapatalk
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
That cat is probably damaged. It may be better to punch it out and drive it home quiet. That should be left up to how it looks when you pull it off.
gnarlybus
AZ
I'm picking it up from a storage lot where I can do tests and stuff but I don't know how much work I can really do to it there. There is a muffler shop up the road that said $100 to swap out the cat with a new on I provide, but I don't want to ruin the new one before I figure out what's wrong.
How easy are to access are the flange bolts to get the cat off? I'm thinking I could breaker bar it maybe. Otherwise I could have the shop take it off and then go home. I'm not sure if they'd put a gutted one back on in CA even though its registered in OR.
gnarlybus
AZ
Does anyone know what size wrench the nuts holding the cat to the Y pipe and the bolts holding the cat to the muffler are? It would help me out. Thanks!
Any tricks to getting at that hard to reach nut on the cat to Y pipe junction?
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
its this size....
gnarlybus
AZ
JerryC
56
Tennessee
2.9
See if the shop will put a cheap aftermarket cat on it. I had one put on mine, it works fine but may not last as long as the factory one. But it will get you home.
Just a thought, maybe the heatshield fell off. If so maybe the shop could fab one up for you.
gnarlybus
AZ
Thanks. I'll look for the heat shield when I get under there. They quoted me $450 to replace the cat!
scotts90ranger
RBV's on Boost
4,325
Dayton Oregon
Engine Type
2.3 (4 Cylinder)
2.3 Turbo
2WD / 4WD
35"
Cats getting hot need a burnable air fuel mixture, usually a lack of spark to a cylinder from my experience from tech calls at work. Just extra fuel will NOT cause an exothermic reaction in a cat, you need oxygen as well, gasoline doesn't burn as well past the stoicheometric ratio so add more fuel and you get less fire, that's why you add more fuel when running hard to cool the exhaust valves...
Anyway, that said I'd look at the plugs and wires, from what I have hard I wouldn't think a TFI module would do that since they're usually all or nothing, same with the pickup in the distributor, could be a bad cap though...
Staff online
Today's birthdays
Shran
April Truck of The Month
