Pressure in cooling system after sitting
Monsterbucks
Warsaw, KY
Mazda
Urgent help needed. I have a 2000 Mazda B3000 3.0. Recently noticed I am loosing coolant. When I went to put coolant in system was holding pressure after engine cooled down even days later. What can be causing excess pressure in the system? Replaced head gaskets 3 yrs ago with new radiator a month old. Possible some water in oil not 100% sure
Uncle Gump
Token Old Guy
TRS Event Staff
13,442
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
2WD / 4WD
Lead follow or get out of my way
Define holding pressure... because if it's leaking coolant... the cooling system really can't hold pressure.
RonD
Official TRS AI
TRS Technical Advisor
8,369
canada
Welcome to TRS :)
Rad cap has two valves
The larger one with the big spring that lets coolant flow OUT to the overflow tank
Then the smaller valve in the center of that cap that allows coolant to be sucked back IN to radiator from overflow tank
As coolant heats up it expands in volume, that's what causes the pressure in the cooling system.
When pressure in rad gets to 14psi(rad cap rating) the larger valve opens and allows coolant and pressure to flow OUT.
As coolant cools back down is shrinks in volume so any coolant that flowed out needs to be sucked back IN
Check overflow tank to make sure its not clogged up at the bottom, coolant can flow in but not back out
Test or replace rad cap
Members online
Today's birthdays
Shran
April Truck of The Month
