4.0 Swap
Leeboi
Springville AL
Guys i Have a 94 Ford ranger with a 4.0 in it, a few weeks ago it blows the motor and cracked the heads i recently bought a 4.0 out of a 94 ford Explorer that has a crank position senor will swapping the sensor for the blank cause any problems, if not what else will need to be looked at, i will be swapping upper and lower intake along with exhaust manifolds
Um, all 4.0s have a crank sensor.
Do you mean a cam sensor?
Leeboi
Springville AL
It’s at the back of the motor in the block
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
that's a cam sensor, crank sensor is near the crank pulley on the front of the engine.
Leeboi
Springville AL
Cool um my question still stands the motor in the truck doesn’t have one the “new” one does can I swap and the new motor run without having to get the computer and wiring harness
Yes, as long as you take the upper intake off and swap the injector harness as well.
You don't even need to swap in the blank slug if you don't want to. You can leave the sensor on there and it can just be along for the ride.
truckerdawg
5
GA via NC Mtns.
4"
31X10.50
Have peace of mind for this is true.
