Cellphone charging port is dead. 2007 Ranger
rdsrds123
2.3
Hi, my 2007 Ranger 4 cylinder recently got the problem of a dead cellphone charging port in the dash. I checked and found a fuse blown. Don't know why it blew. I think it is number 34 or 35, in the passenger kick panel. I checked for power to the fuse and it was there, so I replaced the fuse. Still, no power to the port where I hook up my cellphone. I checked with a volt meter the port. No power. Any ideas what I should check next? Thanks!
Utah
4.0 v6
Check for voltage at the fuse. Should be 12ish volts. Check with the positive on the fuse and the negative grounding out to a good solid ground.
Sent from my SM-G900V using Tapatalk
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I don't see anything listed as a cell phone charge port in the wiring book.
Make sure you have power and ground, if those are good the socket is worn out, it happens.
Doofy
7
Alaska
3.0
Shit Happens...Then You Die.
Some power cords have their own micro fuse, especially cell phone cords.
Spott
TRS Banner 2012-2015
21
SE Idaho
Engine Type
2WD / 4WD
Are you sure this isn't some aftermarket/3rd-party/DIY part? You're probably going to have to get in there and trace the wires.
Staff online
Shran
April Truck of The Month
