1994 Ranger Ranger failrd Calif Smog Test
Beachbummmer
Att: DieHardFord
My 1994 Ford Ranger failed Smog check today. It failed the new Low-Pressure Fuel Evaporative Test. I was told that it probably was the hose that went to the top of the fuel tank. I am guessing that this is part of the circulating fuel system. I am looking for ideas, looking for a diagram of fuel system and where else the problem might be. In the test they pinched off a hose in the engine compartment and applied air through the gas filler tube, the pressure must hold for several minutes, it did not. Every thing else pass the test.
Help
I think you have a great idea with an Emissions forums on Ranger Station.
Bamaprez
You need to also look at the filler hose on the ranger. I've had 5 rangers and after about ten years they all have developed crackes just above where they clamp to the tank. If you get a splash of gas under the truck after you fill up thats the problem.
John
Staff online
Shran
April Truck of The Month
