Oil pressure gauge flipping out.......
sweetwaterbroncoII
Sweetwater, TN
2.9L
My oil pressure gauge keeps going from normal to low normal to low normal to low.....could the gauge just be going bad...I have bought an aftermarket gauge to install, but I was just curious if the factory ones go bad?
Ranger Sport Honduras
Zoom Zoom
OTOTM Winner
Solid Axle Swap
197
Honduras
Mitsubishi/Ford
3.0/2.3
Fortune Favors the Brave
maybe is not the gauge, maybe the sender unit, i have some issues with mine too, it goes dead when the truck is cold, once the engine warms it works fine. check your sender unit first
sweetwaterbroncoII
Sweetwater, TN
2.9L
True...I was just curios, I'm replacing it this weekend!
COPPERHEAD85
41
west tennessee
ford
302
did you get a manual gauge?
if so pick up some plastic wire loom to run the line thru.
sweetwaterbroncoII
Sweetwater, TN
2.9L
Yeah I got a manual gauge...but I also bought copper tubing so I won't have to use the plastic tubing....do I still need the plastic wire loom?
Wicked_Sludge
43
Westport, WA
3-point-GO
you dont need wire loom for either, it just makes it look nicer.
COPPERHEAD85
41
west tennessee
ford
302
and protects the line from getting a hole rubbed in it (insurance).
don't like the copper line,Ive used the plastic line for more than 20 years in almost as many vehicles with no trouble.
sweetwaterbroncoII
Sweetwater, TN
2.9L
I heard that the plastic line could melt....is that a common problem?
Wicked_Sludge
43
Westport, WA
3-point-GO
only if you let it lay on your exhuast manifold :icon_thumby:
Zoom Zoom
OTOTM Winner
Solid Axle Swap
197
Honduras
Mitsubishi/Ford
3.0/2.3
once i used a oil pressure gauge but mine was electric i just replaced the bulb with the needle gauges bulb and connectedthe wire, its easier to do :)
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
Engine Type
V8
6.6L
2WD / 4WD
5"
35"
Easier to do, but you essentially have the same guage as the stock unit. If I can have a mechanical unit, I would much rather use it than have an electrical sensor telling me what it thinks the pressure is.
I put in a mechanical guage with the plastic tubing over 2 years ago and it's still working fine.
Staff online
Shran
April Truck of The Month
