87 2.9L tank pump won't work when rail pump is plugged in
manley
4
Richmond, IN
2.9 swapping to 4.0
Wut?
Some history:
Bought the truck from a guy who had the truck running, but it puked coolant out of the exhaust. Blown head gasket, so he swapped in another 2.9l and never got it running again. He sent a video of it running with the first engine. I think the truck sat for a long time before he bought it.
So far, I fixed a missing hose in tank between pump and hard fuel line and new EEC relay. Inertia switch tests fine. Fuel pump relay test fine. Both pumps worked when removed and directly wired to 12V.
When the high pressure pump on the rail is unplugged, the tank pump will turn on. When I plug the high pressure pump in, neither will work. I'm thinking pinched wire somewhere.... unless someone else has some knowledge to share with me? Strange, strange problem.
Jump 12V from the battery to the plug near the LH side of the engine bay where the fuel pump wires split off. It will be a small plug with a single pink/black wire going in and two of them coming out the other side, somewhere more or less right below the brake booster.
If both pumps run that way suspect a damaged wire between the relay and that plug that is unable to carry enough amperage to run both at the same time.
manley
4
Richmond, IN
2.9 swapping to 4.0
Wut?
Got it! Thanks for the help! Both pumps turned on when I connected the pink and black wire to 12V. Started tracing it back, splice looked good, not damage to be seen. Pulled the inertia switch off and jumped the wires, truck fired right up. Obviously I did something wrong when I was checking the inertia switch. Appreciate the help a lot!
