M5R1 shifter: rebuild stock, Core, or Hurst?
curtis73
6
Harrisburg, PA
Mazda
4.0
Common thing... shifter is sloppy.
Thoughts on new bushings in the stock shifter?
How about a Core shifter?
Or a Hurst?
Which one to do?
lvwill
143
Las Vegas Nv.
ford
Engine Type
2.3 EcoBoost
2.3 Ecoboost
2WD / 4WD
2WD
The rebuild kit deal for the stock shifter is pretty cheap.
Core is building new short throw shifters with Hurst parts for a couple hundred dollars.
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
Just get the rebuild kit. The aftermarket shifters aren’t vented and cause more issues down the line. Plus it’s a ranger. The stock shifter will prolong the life of the trans by NOT allowing speed shifting. Spend your money elsewhere.
curtis73
6
Harrisburg, PA
Mazda
4.0
Good point.
Are there upgraded bushings, or just stock replacements that need to be done every 50k?
Delrin? Aluminum? Bronze?
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,827
SW Iowa
Engine Type
V8
5.0
Stock replacements are cheap enough and easy enough to change I wouldn't bother with "better" ones.
The kit is like $15 on Amazon.
curtis73
6
Harrisburg, PA
Mazda
4.0
Did the bushing repair. Much better. Still a bit of a long throw but at least not in the glove box.
Staff online
Shran
April Truck of The Month
