m81mclaren
- Oct 2, 2018
- Reaction score
- 0
- Location
- CA
- 1980 M81 McLare
Ok this is a great site and has been helpful to me identifying some details on my engine, carb, and head (thank you!) during the process of the rebuild of my 1980 2.3 carb Turbo M81 McLaren Mustang. I don't have a Ranger but recent searches on my Duraspark setup led me back here again so I decided to join. If I'm in the wrong spot or you don't want me here please let me know!
Symptom- intermittent engine cutouts leaving me stranded
After a lengthy rebuild process on my top end (documented on the 2.3 section of FourEyedPride forum) I am having a recurring running condition problem while I try to get the car ready for CA Smog testing. The symptoms are after 24+ years off the road on my first drive I went 20 miles trouble free in 95degree weather then it stalled like it was running out of fuel (felt electrical as it was more like an off/off switch) while driving an even 35 miles an hour. Then on the side of the road cranked and cranked but no fire at all. Then after a few minutes and lots of pedaling I would get it to fire and it would drive a few hundred yards then the same thing. This happened several times but made it home. I strained the gas in the fuel tank, replaced the fuel filter and added an in-line filter. After a restart and drive attempt #2 the following day it died out 1/4 mile from home again with several restarts but could only go 50 yards before it would die again. It starts and idles just fine but will inconsistently just stall out even at idle. I suspect something in the ignition system as the fuel filter appears just over half full even after the stall and I was able to drive on/off the tow truck after a short cooldown. It seems to break up occasionally above 3,000 RPMS.
If it helps, 7 years ago I had the gas tank rebuilt, installed new seals, all new fuel lines, & the carb rebuilt in order to just get it started. Since that original restart I rebuilt the head and turbo this year to cure smoke issues that pulled it off the road originally back in 1991. Last week I put in 6 gallons of fresh fuel for the first drive where I found this issue.
Current setup (looks factory original to me although part numbers seem earlier?)
Duraspark Ignition Control Module- # D8AE 12A244 AB number on face of unit
Distributor # 0F806 E0ZE 12127 BA on tag attached (Single Vacuum inlet)
Coil # D5AE 12029-AB
My buddy is an experienced Pinto racer and has 2 that he SVO swapped who was with me when this occurred and he was a bit stumped and suspected the Duraspark system or the original fuel pump. He was told Duraspark is garbage and has typical problems. True? It looks like there are aftermarket replacement parts (ICM and Motorcraft, distributor, coil, etc.) but I'm not sure if there are nuances between years as some sites show the available LX215 and LX212 . Should I start with a distributor pickup, then try ICM, then distributor? Is this a lost cause?
Appreciate any insights that will help me get on the road!
