is it possible to put twin stick on np205 behind a zf???
ford1386
Solid Axle Swap
Gardners, PA
306
I put a 302, zf 5 speed and an np205 t case, and am wondering if I can install a twin stick kit on the zf transmission to shift the np205.......
ford1386
Solid Axle Swap
Gardners, PA
306
Any pics and/or part name and numbers would help
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I'm sure it's possible. I can't say that I know how to do it.
Now, on a related note, one of these days you are gonna have to show me how you got a ZF in there.
ford1386
Solid Axle Swap
Gardners, PA
306
3" body lift and its a piece of cake
gwaii
2010 OTOTY Winner
OTOTM Winner
2010 Truck of The Year
66
haida gwaii
ford
460
you'll probably need to do a bit of fabbing.on mine i actually removed the t-case shifter boss from the tailshaft housing to get enough clearance for the top(h-l) rail on the 205.since this boss is right in line with the rail,a shifter bolted to this boss will have no leverage against the top rail to move it.the lower(2-4) rail would be no problem.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
What's that? Chop the floor up and add 2 inches to the trans tunnel?
Eh too much work. I'll just bob the frame of a 250 and drop the B2 body on it.
ford1386
Solid Axle Swap
Gardners, PA
306
Talked to jb custom fab and they supposedly make a bolt on kit
Today's birthdays
Shran
April Truck of The Month
