Bought an '89 B2 with 148K that was sitting for 4 years because it needed a heater core, I guess. Got it running real good after flushing the fuel system, new filters, 6 new injectors, tune up, oil/coolant change, heater core, and other odds and ends. Basically a cake walk getting it going again. Tranny shifted smooth and concise... for the first week or so. The other day after getting off the highway, I took off from the stop light and it felt like it was in neutral for a second. When the revs hit about 1,500 it engaged drive and of course shocked the drive train with a clunk. 1-2 shifted perfect (always does), but 2-3 it flared before engaging. Engaged overdrive fine but I don't drive any automatic in OD in town. When it's cold it engages drive just fine and doesn't fall out of gear at a stop, flare on 2-3, or slip at all. When it's warm, after about 20 minutes of driving, it still engages reverse perfectly but hangs up when shifting to drive unless I touch the gas a little bit then thunk and it's in. If I don't touch the gas it'll hang for a bit then slowly hunker down and engage. 2-3 shift flares (about 500RPMs worth) before engaging but does not slip at all once it's in. Overdrive engages fine but I've noticed a periodic shudder. At a stop it will fall out of drive until I tap the gas a little. I checked the modulator and it's not leaking anything, fluid looks new and smells good, and doesn't leak a drop anywhere.
I'm going to replace the filter and fluid in a bit, but wondering if anyone has any ideas otherwise? I haven't seen another issue like mine and I've spent a long time researching these pieces of shit.
Long story short...
Cold:
Engages reverse, drive, and all other gears perfectly.
Hot, after being driven for 20 minutes:
Engages reverse fine
Hangs up when engaging drive
Have to touch the gas to engage drive
Falls out of drive at a stop
2-3 shift flare on upshift and downshift
No slipping otherwise
Engages/disengages overdrive fine but with periodic shuddering
Personally it sounds like it's time for a rebuild. Generally a problem when cold but not warm is a lack of flow.
