CP2295
I have a 92 ranger 4.0 auto. My donor engine is from a 94 explorer. I have the 410 comp cam ill be installing. I see you have installed yours a few years ago. Would you mind answering a few questions?
What is the power increase I can expect to see from this cam? strange no one has posted numbers that ive seen so far ( Im doing: headers, exhaust, cam, Efan, and BBK TB. )
Is this cam install just like the oem cam? or will i have to degree it?
I called smithbros they said there are two lengths and i have to choose they cant tell me with one i need. The one you mentioned and a shorter one. adding to this i saw this posted on abother thread: Intake needs to add .081 to the pushrods
Exhaust needs to add .098 to the pushrods. So I need different length for intake/exhaust?
You mentioned in another post that you used stock springs on yours. Then said you must use comp 988 springs on this post. can you clarify?
Ive also read that some people used the comp springs on stock head and retainers? can I just get new oem style springs or do i need the comp ones?
I called Mizpah Precision about the rebuilt lifters but the number is not in service. My donor engine ticks on first startup when cold. thats why i wanted to rebuild the lifters. any other places to do so?
The engines not apart yet so I dont know the rocker conditions yet. If they dont look bad can i reuse them? does any one make a good roller rocker setup for this engine that would be same price as changing to sealed power ones?
Appreciate any infor I can get. Im trying to get the ball rolling. Im suprised there is no sticky for this cam swap infor.
donor truck engine has 105K has good power runs good. Not a rod knock or exhaust leak. definitely a top engine tick when cold
I dont have experience with the delta cam grind but be wary of using their rocker shafts, the sealed power rockers are superior imo they have bigger oil holes and much larger pads where the rocker rides the valve. I got 12 on ebay for $140 and 1/2 labor for a machine shop to replace them. Worth the extra dough. 5.550" overall length pushrods and 3/16" closed ball end, and 5/16" tube on the pushrods from smith bros, cost me $85 for all 12 shipped. I dont care what anyone says u must use dual valve springs comp pn# 988-12.
