schekan
- Apr 27, 2009
- Reaction score
- 1
- Location
- Archbald PA
- Make / Model
- ford
- Engine Size
- 4.0
First, Admin feel free to move to proper area, I wasn't sure where to post this. But wanted to give back to the forum I have used so often. My story may help others. I have attached photos as well.
My story is , 4.0 94 Ranger XLT. Most reliable truck I have ever had all of a sudden stalled, then had a hard time starting. Acted like it starving for gas.
So i did the obvious and replaced the fuel filter and pump. No change.
I ran the diagnostics with my code reader. And it had MAF codes 157 and 158.
I hit the junk yard, found a MAF sensor. Did nothing to change the stalling issue, truck was not drivable. It would stall seconds after starting. So for the hell of it I unplugged the MAF and it ran. Not the best but it ran. And from the forums I found out that is because it runs in a closed loop when there is a complete failure of a major sensor.
So I bought a new MAF and still no change. It was really pointing to the PCM, I removed the PCM and did a visual. I am an IT professional and have been working on PC's for 20 years, I can spot a bad MB by looking at the Capacitors pretty quickly. Well I saw no swollen tops, or leaking tops. So I put it back in and checked every ground and even ran wires directly to the MAF sensor. And still nothing.
So I decided to have a closer look at the PCM. I pulled both covers, got a really bright LED work light and a magnifier. And was amazed at what I saw. There was one Cap that blew out the bottom, and a diode that was crusty green. Not good. So I ordered a reman on Rockauto and it solved all issues. It runs like a bear again.
I wanted to share photos of what a bad PCM can look like with a visual inspection. Hope this helps someone, even if it's not the same symptoms if you suspect the PCM and see something like this then it is definitely bad.
