Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Lighting/Illumination
Notices
Lighting/Illumination This forum is for headlamps, auxillary lighting, interior lighting, and LED conversions.
Reply
Thread Tools Display Modes
Old 02-28-2012, 02:16 PM   #1
skoal
Vehicle Year: 1995
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: daily driver and mess around
skoal is on a distinguished road
Default taillights not working
when i turn on my running lights, my brake lights and reverse lights work but my tail lights will not work. i think its a ground problem but im not sure. any ideas?
skoal is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 02-28-2012, 02:31 PM   #2
exbass94
exbass94's Avatar
Vehicle Year: 2006, 1994
Vehicle Make: Ford
Vehicle Model: Ranger, Explorer
I use this vehicle for: Pavement Poundin'
exbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really nice
Default
Did you check the bulbs? Don't assume they're good just because the brake lights work. The brake/tail bulbs are dual filament bulbs. It's possible the filaments for the brakes work, but the filaments for the tails don't.
__________________
2006 Ford Ranger Sport 4x4 2-dr Extended Cab, 63k miles
1994 Ford Explorer Sport 2-dr 4x4, 203k miles
1992 Honda Accord EX, 182k miles
1994 Ford Bronco XLT (project)
2014 Subaru XV Crosstrek, 33k miles (wife's)
exbass94 is offline   Reply With Quote
Old 02-28-2012, 03:11 PM   #3
skoal
Vehicle Year: 1995
Vehicle Make: Ford
Default
yes i checked the bulbs and replaced one but still have the same problem. i checked fuses too.
Old 02-28-2012, 08:34 PM   #4
rtg143
rtg143's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: F150 XLT
rtg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant future
Default
Take a look under the bed. There may be a connection problem there. Maybe a trailer connector was installed and has a problem there. The ground should be okay because the stop/turn use the same ground.
__________________
Bert
rtg143 is offline   Reply With Quote
Old 02-28-2012, 08:32 PM   #5
azreb
Junior Member
Vehicle Year: 2004
Vehicle Make: Ford
I use this vehicle for: Looking at
azreb has a spectacular aura aboutazreb has a spectacular aura about
Default
It is not likely to be a ground problem if your stop lights work. Dual element bulbs use the same ground, through the base of the bulb. If your fuse is good (best to check it with an ohmmeter--sometimes the fault is not visible), then I would suspect a broken wire or faulty connector.
azreb is offline   Reply With Quote
Old 04-04-2012, 10:29 PM   #6
spitse
Junior Member
Vehicle Year: 2000
Vehicle Make: Ford
Vehicle Model: Ranger 4x4
spitse is on a distinguished road
Default
Did you find a resolution? I am having the same issue.
spitse is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
