Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
- Aug 2, 2000
- Reaction score
- 8,527
- Location
- Nocona, Texas
- Make / Model
- Ford Ranger
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 / 2.3 Ecoboost
- Automatic
- 2WD / 4WD
- 4WD
- Total Lift
- 6-inches
- Tire Size
- 33x12.50x15
If anyone has access to any of this information, I need to get it to add to the Tech Library. I have some information on the engine and transmission:
https://therangerstation.com/tech_library/pdf_documents/2019-Ranger-Tech-Specs.pdf
But I need more detailed information such as:
Axles used
Ring gear dimensions
Axle shaft size and spline count
Gear ratios used
Axle codes
Also, what transfer case is going in to this? I know 4LO is 2.717:1.
Anybody know what turbo Ford uses and how much boost?
Axles used
Gear ratios used
Axle codes
