Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Axles, Brakes, Wheels & Tires > Wheels & Tires
Notices
Reply
Thread Tools Display Modes
Old 07-13-2018, 07:03 PM   #1
Boyelroy2000
Boyelroy2000's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger XLT
Boyelroy2000 is on a distinguished road
Default Tire size vs gearing
My 1997 2wd has the 2.3 , 5 speed, and 3.73 rear end gears. I plan on leveling it and fitting larger wheels and tires.As of right now it is sitting on 225/70/R14 tires. If I make the switch should I move up to the 4.10 rear end gearing? I'm considering moving to a 235/75/15 or 245/75/15. I'm leaning towards the 4.10 gears but I don't want to completely axe my gas mileage. I just want a second opinion on this.
Boyelroy2000 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 07-13-2018, 07:54 PM   #2
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Well, do you ever have to go uphill?
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 07-13-2018, 08:28 PM   #3
ericbphoto
ericbphoto's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger, 4X4, "Splash"
I use this vehicle for: around farm, around town, trail riding, rock crawling
My credo: In theory, theory and practice are the same. In practice, they are different.
ericbphoto is just really niceericbphoto is just really niceericbphoto is just really niceericbphoto is just really niceericbphoto is just really nice
Default
Bigger tires and changing ride height, which affects aerodynamics will have a slight negative effect on gas mileage no matter which gears you run. Driveability is what you get by changing gears. Being able to keep your engine in a decent rpm range while going uphill or towing is something most of us like.
Go to the "how to tech" page and follow the links to articles about gear ratios, tire sizes, etc. There is a cool chart there that gives good comparisons of engine rpm vs gear ratio and tire size. That will give you a good idea of what gear ratio will keep your engine rpm in the right range. You don't have to guess.
This message composed solely of recycled electrons. Go green!
__________________
Eric B.
PROJECT: 1993 Splash 4X4
ericbphoto is offline   Reply With Quote
Old 07-13-2018, 08:30 PM   #4
ericbphoto
ericbphoto's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
delete
__________________
Eric B.
Old 07-13-2018, 08:45 PM   #5
Boyelroy2000
Vehicle Year: 1997
Vehicle Make: Ford
Default
Quote:
Originally Posted by ericbphoto View Post
Bigger tires and changing ride height, which affects aerodynamics will bigger have a slight negative effect on gas mileage no matter which heard you run. Driveability is what you get by changing gears. Being able to keep your engine in a decent tomorrow range while going uphill or towing is something most of us like.
Go to the "how to tech" page and follow the links to articles about gear ratios, tire sizes, etc. There is a cool chart there that gives good comparisons of engine room vs gear ratio and tire size. That will give you a good idea of what gear ratio will keep your engine rpm in the right range. You don't have to guess.
I understand the fact that my efficiency will be slightly downgraded by larger tires and differing aerodynamics, but I was really hoping to find some info on the gas mileage I could expect with such a change. If I opt for the 235/75s the truck would essentially act like a 3.45 (3.41 was the true ratio) which is perfectly driveable in my experience (My buddy has an 89 Ranger with 225/70/15 with a 3.45 rear end and it does fine). If I go to the 245/75 then I'll definitely opt for the 4.10 gearing. Thanks for the help though man!
Old 07-13-2018, 10:53 PM   #6
Vehicle Year: 1994
Vehicle Make: Ford
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
Go here: http://www.therangerstation.com/how-...er_tires.shtml
Plug in your numbers
If you need diameter in inches go here: https://tiresize.com/calculator/
Yes your tire choice would set 3.73 actual ratio at 3.45, a change to 4.10 would put you back at actual 3.82 so Performance and MPG would remain "close", as would speedometer, the larger tires are 1" wider, so more friction and heavier which drops MPG a bit, also harder on the brakes so slow down heavier wheels
RonD is offline   Reply With Quote
Old 07-14-2018, 06:44 AM   #7
ericbphoto
ericbphoto's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
gas mileage numbers are the hardest to estimate. It doesn't sound like your proposed changes will result in what I would consider a large change in mpg. It might not even be enough to notice unless you have some really accurate way of collecting exact data.
__________________
Eric B.
Old 07-14-2018, 10:08 AM   #8
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: DD tow boat
kimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to behold
Default
You should be OK i believe you can get a different gear for the speedo senser to avoid the blue light special?
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 07-15-2018, 01:57 AM   #9
Boyelroy2000
Vehicle Year: 1997
Vehicle Make: Ford
Default
Well that's a good thing. Economy is important on my tight college budget haha.
Old 07-15-2018, 01:58 AM   #10
Boyelroy2000
Vehicle Year: 1997
Vehicle Make: Ford
Default
Quote:
I'm definitely going to have to check because I don't want a speedo reading 10 mph off lmao
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Think of Changing Tire Size Like Changing Gearing Blown General Discussions 7 04-19-2015 01:39 PM
Axle swap. Debating size/gearing tsayyote Ranger Axles 6 12-23-2014 10:42 PM
question about 05 fx4 tire size and gearing blh0007 Fullsize Ford Trucks 15 07-29-2012 03:56 AM
Question about gearing/tire sizes RangerJoe03 Wheels & Tires 8 11-12-2009 12:46 AM
what size will work with out gearing? pillen140 Wheels & Tires 9 01-01-2008 11:42 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
