"Water Leaks" Wet Drivers Side Floor n Rear HeadLiner.. "Pass Side AirBag Removal"
Mike Tech
Hello, I am want to know where the water is gettin in..
My Drivers Side Floor is wet (Under Floor Mat)..
My HeadLiner is Wet (at the Rear Window)..
I also want to know how to Remove the airbag from the Pass
Side.. I want to Swap out the Pass Side AirBag Cover..
Thank You,
Mike Tech
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
sounds like the common 3rd brake light is leaking. just run a bead of silicone around the lens.
dunno on the airbag.
slammer67
Solid Axle Swap
Salida, Colorado
ranger
x2 on the third brake light leaking, mine was doing that too.
check all the grommets in the engine compartment, like where wires pass through, maybe theres a leak there. it could be a heater core leaking also.
not sure on the airbag, just be careful and unhook battery when you try it.
Mike Tech
Heater Core Leakin on my Drivers Floor???
slammer67
Solid Axle Swap
Salida, Colorado
ranger
Actually, I think the heater core is behind the glove box somewhere, so probably not.
corrond56
Trinity, NC
3.0
to take out the air bag you need to first unhook the battery. once that is done open the glove box and push in from the sides so the stops clear and let it hang all the way down. there are two bolts on the bottom side of the air bag holding it in place. undo those and the air bag slides out and has a wiring harness that needs to be undone.
Staff online
Today's birthdays
Mudtruggy
May Truck of The Month
