Wiring Aftermarket Fogs using existing wiring
jetblack02
4.0 Liter
02' XLT Ext. Cab, 4.0 SOHC, Auto, 4.10 Trac-Loc, Dynomax Ultraflow Cat. back.
Hey guys, I recently mounted 2 Bosch Halogen fog lights on my truck, but haven't wired them. I was wondering how easy it would be to simply clip the wires from the existing fogs, and wire up the new ones, being as there is already a relay and what not reducing the need to get a harness for them. Yes i have also searched for an answer but didn't really find what I was looking for.
Haywire6000
RBV's on Boost
Lewiston Maine
1997
2.3 Turbo Four Plug Head
As long as your aftermarket fogs are no more than 100 watts each I would say you would be fine.
jetblack02
4.0 Liter
Alright sounds good. Any specific things to know about the wires going to the bulbs? I'm assuming that Red is the hot lead, brown is ground, but blue I don't know what that does.
Haywire6000
RBV's on Boost
Lewiston Maine
1997
Usually there are two wires... Anyway, get a multi meter, connect the brown to the ground on the meter and connect the positive to one of the other wires, turn the fog on ( the switch on in the cab) and see if you have voltage, if you don't try another wire. If you do great! you know those are your wires. One tid bit of advice, don't use tape, get shrink wrap...
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,524
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
Check out the wiring diagrams in the tech articles section of this site. That should help you figure out the wires.
Sent from my SM-G920V using Tapatalk
ericbphoto
TRS Event Staff
GMRS Radio License
16,524
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
Wow. I was on my phone last night when I replied. Now, as I look in the tech articles, I don't see a good diagram for you. Here is one that might get you close.
Not sure why you are seeing 3 different wires. Is that really the fog light harness? Go with Haywire's technique and you see what you can find out. This is a good, basic project to practice your electrical investigative/troubleshooting skills.
jetblack02
4.0 Liter
Yeah I may have to double check on that. Thanks for all the advice and that wiring diagram eric, i think that is what I needed!
Staff online
Today's birthdays
Shran
April Truck of The Month
