Bushings for Skyjacker sway bar links?
94firstranger
TN
I've got a set of Skyjacker sway bar end links and need to replace the bushings in them. I attempted to make a quick-disconnect setup by drilling a hole in the bolt and using a cotter pin. It worked, but chewed up the red bushing b/c I wasn't smart enough to put a washer on there. Ugh.
The Skyjacker part number is SBE734 . I cannot seem to find the correct bushing for it. Does anyone know what bushing I need for these?
Thanks!
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I seem to recall they used standard hourglass type shock bushings. I've seen Energy Suspension urethane ones available at O'Reillys & others (maybe Daystar urethane as well). Sorry I don't have pt#s, though they should be easy to match up.
