Coil spring set up for dana 35 4x4 ranger
z.korz
Gardnerville, Nevada
4.0
I have an 89 ranger with the 4.0 and 4" lift beam pivots. I was wondering why the best coil spring set up would be to keep my 4 lift, add a little travel and have a softer set up to play in the pits now and then and maybe catch some air. I plan on extending my radius arms but I'm trying to come up with a plan for my coil spring set up. What has to be done to be able to fit early bronco coils or would the skyjacker softrides be good enough with some bilstiens or fox 2.0 and f250 shock mount?
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
The Skyjacker 6" ttb coils work great with 4" drop brackets; that's the exact setup I have on my truck. They are softer than Superlift or Rough Country, but they are still relativity stiff compared to XJ or early bronco coils.
How much wheel travel are you looking for? Rock crawling or desert jumping?
z.korz
4.0
I don't need a ton of travel. I live in a place with rocky dirt roads and my set up right now is way to stiff. My whole truck shakes the whole time and I'm looking to be able to go good speeds on those roads and not hit the roof every bump. I plan on jumping it now and then but its not gonna be a racer or anything. I have money to buy skyjackers and some nice shocks and radius arms. I have heard that even the sjs are even too stiff and they are the softest ttb coils. Don't really wunna fabricate new coil buckets for eb coils
z.korz
4.0
what is the compressed length of you're coils? We basically have the same truck��
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
What are going to do for steering? If you're doing some jumping then some coil overs may be a good idea
My Skyjacker 136 coils sit at 39cm, or 15.3 inches, with the washer and isolator
z.korz
4.0
Well if I just get the sjs then I could get away with a drop pitman arm right? If not maybe the superrunner steering if I go coil over or even softer coils.I'm just nervous about doing coil over with drop brackets. Would that put more strain on my frame and the brackets themselves?
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
There wouldn't be any more strain with coil overs vs just coils. You would need to remove the coil bucket and make a top mount for the coil over of course(and on the beam as well)
The Skyjacker FA600 arm should be long enough to get your steering linkages in line with the beams. A Swing style or K-Link/Superunner setup both have advantages though.
You'll need fully adjustable camber/caster bushings so that you can dial that in after your lift it.
What are you using for Radius arms?
z.korz
4.0
I was actually planning on making radius arms out of my old ones after I get the suspension set up. Probably around 12" longer so I don't have to deal with the crossmember. I think I'm gonna stick with regular coils
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
Making your own arms is a good plan. I've done a few sets and they work well with the stock bushings. I can post some pics of them later.
The Skyjacker coils will probably sit at around 15" or slightly under that on your truck, being an extended cab.
z.korz
4.0
Isn't 15" The ideal 4" lift or am I wrong
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
The factory coils on our trucks will sit at about 10-11", so at 15" you'd be at about 4-5" of lift, which is right where my truck is at.
z.korz
4.0
OK that makes sense. What is the set up for you're rear? Leafs are expensive! I dont plan on towing regularly. Maybe like 2 times a year so that's not really a factor but I do haul my dirt bike and sometimes camping gear and stuff in it but that's about it.
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
I have Skyjacker FR34S leaves in the rear along with some Belltech 6400 shackles, though I am not using the bottom hole as that made the rear too high. I have about 4" of lift on the rear and 5" on the front.
You could run factory blocks, explorer leaves and shackles to get around 4" of lift. The explorer leaves are quite stiff though. 4" blocks work too, but the axle wrap with those is really bad. Make sure you get good U bolts.
z.korz
4.0
What is the advantage of bell tech shackles over stock? Might be a dumb question but I haven't got to researching the rear end yet as I have spent most of my time looking into the front end.
BlackBII
Ranger Custom
OTOTM Winner
Truck of Month
982
UT
Engine Type
2WD / 4WD
They are longer than the factory shackles, which moves the leaf spring down, effectively lifting the truck.
Staff online
Today's birthdays
Shran
April Truck of The Month
