master hec0
- Aug 29, 2009
- Reaction score
- 5
- Location
- okotoks alberta canada
- Make / Model
- Ford
- Engine Size
- 4.0L V6
so i noticed that my marker light on the right side under my headlight was not working it would still signal but just not light up as a marker so i figured that one of the 2 filaments was burnt out. went to napa and got a new bulb.
now my marker works but my right signal light will not light up. none of the right signal lights light up. what should i check 1st? the fuses should be fine since the other side the lights work. also i went and got another bulb from ford to see if maybe i had gotten a dud. same issue
