elementaltoad
- Nov 16, 2014
- Reaction score
- 1
- Make / Model
- Ford
- Manual
I have a 1999 2.5 5 speed with an issue. This mainly happens when it is cold.
When cold, if I try to drive the truck it wants to stall when coming to a stop. It doesn't idle rough or shake it just cuts off when coming to a stop. This frequently happens when cold while coming to a stop or putting the clutch in while yielding for a turn. As you can imagine it is a bit dangerous as I lose power brakes and steering.
If I let the truck reach operating temperature it won't stall, however if I rev it or put the clutch in just after the top end of a gear it wants to idle rough and sounds as if it is missing on a cylinder or two.
I have replaced:
-upper and lower intake gaskets
-IAC and gasket
-EGR gasket (and cleaned the ports)
-Valve cover gasket
-Cleaned and replaced the lifters (they were noisy)
-Cleaned the MAF
-Replaced fuel pump
-Replaced Filter
-Cleaned injectors
-Cleaned fuel lines
-Filled up with 93 Octane (back on 87 now with the same issue)
-Checked all vacuum hoses and checked vacuum while at idle
- NO CHECK ENGINE LIGHT
I did notice that if I rev it while the vacuum gauge is hooked up, it will come back to idle but will idle rough and vaccum drops dramatically.
It appears this is common with these trucks, but I have not read of anyone solving the issue yet. Most suggestions just say "let it warm up" or "don't rev it high". However these are obviously not solutions to a problem and during rush hour traffic I need to be able to count on getting the vehicle up to speed quickly without it stalling or idling rough.
If it keeps this up maybe it's just time for a LS swap, or 5.0? Any suggestions? Thanks!
I have replaced:
-IAC and gasket
-Valve cover gasket
-Cleaned the MAF
-Replaced fuel pump
-Replaced Filter
-Cleaned injectors
-Cleaned fuel lines
