96 ranger hitch install
98v70dad
38
GA
3.0L
2WD / 4WD
2WD
I'm going to buy and install a hitch on my ranger.
The ranger has a bed liner and a fiberglass cap. Will I have to remove either or both of those to put in the trailer wiring harness? My bed liner seems to completely cover the sidewalls.
I can figure it out once I get it but would like to know what I'm getting into. Thanks.
Dangerrangers
Ohio
94 and 04
4.0 s
Do it right the first time !!!!!!!!!!
You will put the trailer harness in from underneath the rear bumper ,you will disconnect the wiring that goes from the left to the right side and connect the new harness in between the two . Buy the harness and don't mess around with the cheap do it yourself splicing kits ,you'll just have trouble if you don't shrink tube all your splices . The harness is fool proof and make sure you hook up the ground wire from the harness to a clean ground.
98v70dad
38
GA
3.0L
2WD / 4WD
2WD
Thanks. So the connection is made from below instead of up in the bed area? Sounds really easy - thats what I was hoping for.
I agree with you about buying a harness instead of making splices. In addition to what you pointed out making a good watertight splice is a lot of work and the price difference is worth it to me in saved effort.
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
There should be a connector on the drivers side behind the bumper, it will literally be 2 plugs that plug into each other and continue along the bumper. Undo the plugs, an your harness goes right in between.
Here's what they should look like:
https://www.etrailer.com/t1-1996_Ford_Ranger.htm
Do not cut your wires, there are plenty of kits that just plug in. Some might even be available at your local auto retailer, Ranger harnesses are really common.
Dangerrangers
Ohio
94 and 04
4.0 s
Your welcome !!!!!!!
98v70dad
38
GA
3.0L
2WD / 4WD
2WD
I got a good answer on my electrical question. Thanks folks. I'm wondering if there is any hitch that is better than the others.
I'm considering this oneby curt since it seems to wrap around the spare tire better than the others. You still have to use a box end wrench to drop the tire, though.
https://www.etrailer.com/Trailer-Hitch/Ford/Ranger/1996/13138.html?vehicleid=1996301986
Does anyone know a better alternative?
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
2WD / 4WD
remove the spare tire and keep it in the bed. I had a 96 ranger and never had to use the spare until the day we needed it and the damn thing was seized and rusted in there. spent more time trying to get tire out from truck than removing and replacing the flat tire. That's just me. you could always make a cable/chain device that lowers your tire when needed. Or you could just add some bars that hold the tire in place and have one side of the bars on a hinge so you can remove one or two nuts and swing the tire down. look up spare tire carriers for campers and you will get some ideas.
98v70dad
38
GA
3.0L
2WD / 4WD
2WD
My 96 ranger already has a spare with a bar and a hinge. It works well. Its a Southern car - garage kept - no rust at all. Most hitches interfere with the bolt that releases the bar that swings down. The curt hitch I linked to will work and doesn't interfere if I don't object to using a box end wrench to loosen the bolt. The curt is not as good looking as the straight hitches that make the spare unusable. I'd rather not put my spare in the truck bed. Thats a good solution but I'd rather buy a different hitch if there are alternatives.
Captain Ledd
39
Michigan
302, 2.3
My Reese hitch works fine.
98v70dad
38
GA
3.0L
2WD / 4WD
2WD
OK. My truck may be different than yours. I've got a 96. Also, reese currently sells several different hitches and 21 years ago they may have had completely different products.
Captain Ledd
39
Michigan
302, 2.3
'95-'97 are virtually the same truck. But yes, 21 years makes a big difference, but I put my hitch on about 10 years ago now. It's the heaviest duty one they made for the Ranger (again, at the time). I have a feeling if it has the bend in it so it'll contour around the tire, it'll be fine.
98v70dad
38
GA
3.0L
2WD / 4WD
2WD
Thanks. I know. I found one with a bend and it will work fine. I don't like the looks of it although it will have to do if its all I can find. My spare has a hinged bar that swings down with a 19 mm fastener that points towards the back that holds it on. The curved bar on the curt hitch just clears the fastener so you can't remove it with a tire iron or socket wrench. You have to use a box end wrench.
Other years of the ranger just had a plate in the center of the wheel that bolted up to some structure above it. You had to man handle the tire to get it out. The positive was that the structure could be relocated forward a bit and you could move the tire forward a bit to accommodation any interference. I could relocate mine also but not without making a big project out of it.
I would like a class 4 hitch and have found that there is nothing currently sold that's a class 4 for my 21 year old truck. I don't have time to go looking for an old one at a junk yard. I've looked on ebay and there are no used class 4 hitches for sale for my truck
So I'm stuck with only a few choices. etrailers has a 3 or 4 and most of them say they won't work with the spare.
The point of my post was to find out if there was anything else out there that I would work that I might have missed. I'd rather not spend over $100 to get something that I don't like that doesn't quite do the job (special wrench needed).
55trucker
183
Oshawa, Ontario
Engine Type
3.0 V6
3.0L
2WD / 4WD
2WD
Total Drop
mild
Staff online
Kirby N.
March Truck of The Month
