New fuel pump got me running but.. (Video)
rusty ol ranger
Im a Jeep guy now.
7,418
Michigan
177 CID
Test the TPS.
If not that...you may be in for a timing chain
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
correct the firing order and confirm timing is correct.
ohm the wires and replace as necessary..
then try it.
SuperAwesomeGuy
Sherman tx
Alright when driving around I run fine above 2500 but lower gives me a lot of shaking and little acceleration. Also I believe my 5 and 6 cylinders are not firing, taking wire off does not affect running even though has spark
Sent from my Moto G (5) Plus using Tapatalk
