Most common on the 1350 rear output is the flat flange - the nice thing about that is the driveshaft side of that is the same bolt pattern regardless of whether you have a 1210 or 1310 style u-joint - it only gets bigger on the axle end (still has a 1310 joint but larger bolt pattern.)
Short wheelbase trucks would have had the double cardan CV style rear driveshaft, hence the different t-case yoke.
Supercabs had the flange then? My std cab longbox had the yoke for the rear output.
Axle end of the driveshaft had the tiny pattern, I drilled and tapped the 8.8 flange to match it. Both ends had 1210 crosses.
I didn't think they went to 1310's until the second gens.
My '83 standard can long bed had a yoke. I swapped the flat glange from a Bronco II and a flange yoke for a 1310 u-joint. I had a new drive shaft built when I swapped in the 8.8.
I thought the BW1350 had a rear yoke on standard cabs, and a flange on extended cabs? Did all the BW1354's have a rear flange only?
I've never seen a super cab that did not have a flange. And yeah, all of the 1st gen rear drivelines I've seen have used 1210 style joints.
My '86 standard cab long box had a flange on the rear output, my '88 short box has a yoke. '89 long bed also has a flange.
I'm sure my small sampling of 20-30 trucks over the years is not scientific in any way but I have a fairly good idea of what pieces were available.
That sounds about right, since the earlier B2's had normal driveshafts rather than the CV style. I think most/all '83-84 B2's for sure, probably '85 as well had rear yokes rather than flanges.
theres a shit ton of drive shaft combinations for the early trucks.
the hi-rider had the same cv joint as the shorter tk manuals...
its the 1210 style double cardan with a 1310 at the front axle.
the rears could be 1310 or 1210 depending on trans and wheel base. 2wd or 4x4...
the c5, manuals, and a4ld...combined with 4x4, 4x4 factory lifted or 2wd plus cab with bed length thrown in make for some out of control shenanigans.
only thing i can say for sure. glass headlight ext cab non hi-rider got 1210 two piece rear drive shaft if it had an automatic. and there were 3 versions of that..
the bronco 2had tulip style cv and cardan style cv with 4x4...some 2wd had single single.
