cranked torsion..kinda bummed by the outcome
basshead
TRS Banner 2012-2015
Calgary Alberta
ford
4.0 bored
i cranked my torsion, but it still doesnt sit high enough for me in the front, i dont wanna max the torsion bars is there any other way to gain abit more hight in the front to even it out cheap $? i measured back clearance and its still 1.5" taller
heres before
and after the crank
brinker88
11/2013 OTOM Winner
OTOTM Winner
36
Williamsport, Pa
4.0L
Looks perfect IMHO
06RangerXLT
54
Georgetown Ontario
4.0L
if you want lift height, open you wallet. if dust comes out, your not lifting anytime soon.
moral of the story, its not cheap. grab torsion keys. thats your only cheap option. oh, your gonna need to buy shocks :)
basshead
Calgary Alberta
ford
4.0 bored
which brings me to another question...i havent changed the shocks yet scince i bought the truck 3 years ago..and they guy i bought it from had no records of having them replaced either.. when i go over speedbumps the front shocks make a noise. like a whommph noise its hard to explain. im guessing they are shot anyways, if i get some decent shocks vs my crappy ones, willl it be stiffer in the front therefor rasing it up an inch or so?
brinker88
11/2013 OTOM Winner
OTOTM Winner
36
Williamsport, Pa
4.0L
Shocks do nothing to lift a vehicle. Their name states their occupation: Absorbing Shock. That's it. May be a stiffer ride depending on what kind you get, but you will gain absolutely no lift out of a standard shock...
My buddy DID gain an inch of lift with those Monroe Sensatrac with coils around them. As for the front, no such thing is made.
JoshT
1,734
Macon/Fort Valley, GA
Engine Type
V8
2WD / 4WD
Basshead, what size tires you running there? Aside from the expensive lift only thing I can think of is to live with it, or get shorter blocks in the rear. Personally I'd live with that little rake, with that it'd set bout level with a little weight in the bed. I wish my truck sat like your does. Mine looks like I'm driving around with the front tires flat, or with Gas shocks pumped up in the rear. It'd be a mean rake for an old muscle car but this is a 4x4 pickup. Guess I need to find some specs for the front suspension and adjust my ride height a little. On that note could you do me a favor? Could you measure from the center of your front wheel to the bottom of the fender. It might help get mine where it needs to be.
Brinker88, I doubt your buddy actually gained an inch over stock height. I expect his springs were sagging and those shocks helped offset it a little. Just my 2 cents though.
basshead
Calgary Alberta
ford
4.0 bored
im running 31 x 10.5 bfg mud terrains. and ill be at my gfs house all week so im not sure if i can get a measurment, but i can try mabie later if you look back on this post tonight or tomorrow i should have it up
JoshT
1,734
Engine Type
V8
2WD / 4WD
Actually you've told me all I need to know. There is approximately a 1.5" difference front to rear and you are running the same size tires I am. I think I can handle the rest from there. Appreaciate the quick reply.
Original_Ranger84
20
Homer, Ak/ Anchorage, AK/Fairbanks, AK
2.8L, 3.0L
Looks better then mine, My bars weren't cranked at all and when I cranked them to the max I only got about an inch out of them.
stiluv
01/2014 OTOTM Winner
Ford Technician
OTOTM Winner
Solid Axle Swap
ASE Certified Tech
3
nevada city, california
ford
Engine Type
V8
5.oh face oh oh oh
2WD / 4WD
Solid Axle Swap 4x4
i cranked my t bars and got about 2 inches which leveled it out pretty good. but i maxed them out and got a little bit longer of a shock.
basshead
Calgary Alberta
ford
4.0 bored
one more question, ive been reading about people disconecting the sawy bar to losen the front end abit while wheeling...is this possible on my 98? or is it a solid axle only deal
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
Disco'ing the sway bar will definitely help for sure. However there is only a limited amount of travel available with the IFS frontend, so once you've reached those limits, the only way to get past them is with a straight axle swap.
The downside of course is more body roll during cornering (which also tends to be a bit more pronounced on '98+ IFS trucks than on '97down TTB trucks).
JoshT
1,734
Engine Type
V8
2WD / 4WD
One more strike in favor of building dad's old 68/70 F-100 instead of my 99. Big Big motor, 4 Speed, manual transfer case, better looking body, Warn 8274, and now solid front axle. Shit I've gotta stop thinking about building my truck and just think about fixing it.
4.0B2
151
Walls, MS
4.0 v6
agreed... keep the 99 stock-ish for a clean dd. fix the old one!
Staff online
Members online
Shran
April Truck of The Month
