Box of Marbles 2000 Ford Ranger 2.5 174k miles
JamesH
That would like piston slap. I would be a compression test and a leak down test
Sent from my Moto Z (2) using Tapatalk
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,088
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Rod knock. Double check the valve train to make sure it isn't the top end.
The motor is toast.
If it was a chev it wouldn't run at all...lol
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
GMRS Radio License
12,641
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
2WD / 4WD
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Time to get an engine from a scrap yard and do a swap. Save any parts that look like they might be good for spares later on.
tomw
46
toenails of foothills NW of Atlanta
ford
Engine Type
2.3 (4 Cylinder)
lima bean
2WD / 4WD
2WD
vertical and above ground
As I posted elsewhere, I think it is cam follower rattle caused by collapsed supports. Get the oil pressure up, and it may quiet down. I suggested changing to a light weight oil for the cold temps you are having... The oil flows from the top of the block(driver side rear) across a small passage on top of the block, machined into the bottom of the head, to flow around a head bolt then to a passage feeding the lifters and cam bearings. The passage around the head bolt might be too tight for thick oil to traverse readily, starving the lifters & cam bearings.
If the oil on the dipstick is like thick syrup, or thicker, it may not want to flow well until spring...
tom
Fredness
28
Sasquatch Country!
Ford Sport Trac
Engine Type
4.0L SOHC
2WD / 4WD
Check timing belt, verify marks.
Members online
Shran
April Truck of The Month
