Crank Position Sensor 94 Ranger
DeferenceFord
Wilmington, NC
So the crank position sensor (CPS) on my truck is gonna need to be replaced and the mechanic wants $600 I don’t have to replace it. Any suggestions on how I go about changing it?
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
You should tell us what engine it is.
IIRC On the 4.0l, it's an 8mm [5/16"] bolt that holds it on right beside the crankshaft on the left side. I would say it's a fairly easy DIY job. Hardest part will probably getting the wire harness disconnected.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Its in the 4-cyl section, so probably a 2.3L.
Those you have to pop the crank pulley and timing cover off IIRC.
alwaysFlOoReD
Forum Staff Member
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Staff online
Members online
Shran
April Truck of The Month
