2001 Ranger key very worn - replacement?
neutronranger
5
Minnesota
4.0L
I've done a little searching on the General forum and didn't find any posts with the answer...
How do you get a replacement key when your original keys are badly worn?
Do I have to go to a Ford dealer and pay a lot of $$?
Or is there a 3rd party that can create the key from the VIN number or some other code somewhere on the Ranger, perhaps?
How much is a fair price to pay?
Thanks,
Eric
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Around me PATS keys go for about $20, give or take, no matter where you buy them.
If you have at least two existing keys that still turn the lock you don't need the new ones programmed, you can do it yourself, as long as one is not a clone of the other.
Most locksmiths that do anything with cars can program PATS keys these days, but all the ones I have dealt with, or know people who have, are just as expensive, or more so, than the dealer.
Dirtman
Former Middleweight Moss Fighting Champion
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
An old rental car hack is to take an old key and just zip tie it under the plastic on steering column. Then you can just have a cheap blank key cut with no chip. As long as the original chipped key is on the steering column the truck will start with a normal non-chipped key.
But like adsm said, if you have 2 keys just buy a blank on amazon for 10 bucks, have it cut at home depot and program it yourself.
Ranger850
Doesn't get Sarcasm . . .
4,687
Tallahassee Florida
Born with a 3.0, looking for a donor V8
2WD / 4WD
2WD
Stock 2"
Stock
Doing things wrong, until I get it right.
I thought they put plastic keys in the newer owner's manuals, just for times like this. My dad still has his for his F150. It's yellow plastic mold and you break it out and can make a copy. IIRC it even says "COPY" or something like that on it.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,775
SW Iowa
Engine Type
V8
5.0
If you do that and accidentally use a chipped key the truck will lock you out.
I don't think they do that anymore. I found a blue one in a '86 Ranger though, very neat idea. I think it was if you locked yourself out you could use it once or twice to get back in.
neutronranger
5
Minnesota
4.0L
would like to have new key created, rather than copied
Since my original key has most of the points worn off, I'd like to have a new key created from the original code/specs. I note that sometimes I put the key in the lock and it doesn't always physically catch and allow the lock to turn. I suspect that means it's on the edge of not working. Thus, I'd rather have a new key created with the original code/specs so I have a key I can call my master, and can have trustable copies made, if need-be.
So, everyone agrees that the 2001 Ranger would have a PATS key?
I do have 2 keys. One is with me in the city, and one is out at our lake place.
I bought the truck used, so I don't know if both are original from Ford, or if one is an aftermarket copy.
The key in my pocket has a metal Ford oval badge, with all the paint worn off.
It sounds like there is a recommended procedure for "marrying" a new PATS key to the truck?
Is there a "Sticky post" on that somewhere in the forum?
Thanks for the advice,
Eric
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
I have had more success making copies of worn originals than doing it by key code. Also, unless you have a copy of the key code already you are unlikely to be able to get it. Ford only keeps that info going back 5 or 6 years.
I do have 2 keys. One is with me in the city, and one is out at our lake place. I bought the truck used, so I don't know if both are original from Ford, or is one is an aftermarket copy. They key in my pocket has a metal Ford oval badge, with all the paint worn off.
Yup. I think 2001 was the first year it was standard on Rangers, but you have just described a PATS key. As long as both are Ford or Stratec keys it is unlikely one is a clone of the other.
Eric
It is not "recommended" it is required. If the key isn't programmed it won't work.
If you have the owners manual check there for the procedure.
On your though it should be place programmed key 1 in the ignition and turn to run for 3 seconds, repeat with programmed key 2, repeat with unprogrammed key 1, repeat with programmed key 1 again.
That's why clone keys don't work for customer programming. The computer needs to see two unique ID numbers from the programmed keys before it allows adding the third, and a clone has the same ID number as the one it was made from.
RonD
Official TRS AI
TRS Technical Advisor
8,369
canada
1999 and up V6 Rangers had PATS, i.e. 3.0l or 4.0l engines
Rangers with 4cyl 2.5l SOHC Lima engines(1998-2001) did not
Rangers got the new 4cyl 2.3l DOHC Duratec engines in mid-2001 and they got PATS at that time, so 2001 could be PATS or non-PATS depending on engine size.
You can remove your lock cylinder and take it, with the worn keys, to a locksmith and have new, less worn out, PATS keys made
A Ford Dealer can often make a new PATS key, or keys, from your VIN
A heads up, if keys are worn out then cylinder may not like NEW keys, it can be worn as well, so grain of salt on that.
As said if you have 2 working PATS keys now then you can add new PATS keys yourself
If you don't then someone with a Laptop and Ford software can add new PATS keys that way, this can only be done by plugging laptop into the truck, I know make sense but some have asked if you can take computer in to have keys added to it, answer is no, but you can Delete PATS from a computer, while its out of the truck, if you have programming software
neutronranger
5
Minnesota
4.0L
more details
I've got a 2001 Ranger with 4WD 4.0L V6.
By the descriptions, I must have a PATS key.
Thanks for the ideas (locksmith, buy blank PATS key & marry it myself, etc.)
I just contacted my local Ford dealer to see what they charge to create a new key (rather than copy my worn key)....we'll see how that option plays out.
edit:
The Ford dealer here in Minnetonka looked up my VIN and said they could not retrieve the key codes and thus could not cut a new key.
They said they could make a copy my current key and program a new key:
$35 for a blank key
$75 to program it
Program it?? Is that what they call the "key marrying" procedure of inserting key #1, then key #2, then the new key?
Since I can do that, there's no way I'm going to pay them $75 to perform the "key marrying" procedure!
Eric
black_demon69
142
AZ
Engine Type
4.0l
2WD / 4WD
A good locksmith can read cuts on current key then cut a brand new working key (not copied)
RonD
Official TRS AI
8,369
canada
As said, adding new PATS keys can be done if you still have TWO working PATS keys(no clones)
But what happens is that many just have the TWO keys now, and lose one..............
And THEN you want the spare key made :)
So now you have to pay to have it added
With PATS its best to have 3 working keys, NOW, so if you lose one you have the option of adding a 3rd yourself
Yes, Ford may only have VIN records 15 years old and newer, some times only 10 years old
So they may not be able to get the key info from VIN
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
edit:
$35 for a blank key
$75 to program it
Eric
It's not really "marrying". That implies that the key will only work with that vehicle, and that vehicle will only work with that key, unless you go through the process again with different parts. If you have another vehicle with the same tumbler set in the locks that key can work with as many vehicles as it will turn the locks for, and the vehicle itself can accept up to 8 keys. The proper term is "programmed" since all you are doing is writing the ID number of the key into a table on the computer. If you must put it into human social terms "introduced" is a far more appropriate one.
The dealer is not going to just do the customer programming procedure that I gave you, unless you leave them both of the old keys. What they will do is go in with the scanner and put it in that way, which takes a lot longer.
As I said before, the dealer isn't going to be able to look up the key cut info because the truck is too old and has aged out of the database. Ford make millions of vehicles a year, they have to draw that line somewhere or they will end up spending all their money on data storage.
As Ron pointed out earlier the lock will wear with the key, and a brand new one may not work perfectly. I've run into this, and it is one of the reasons that a copy of the existing key will be more likely to work well than a code-cut one. Also, code cut keys can just be poorly done, it takes far more skill to do it that way. You would be amazed at how good a cut even an old, worn out key can give when being copied. I've made copies of keys that could be pulled out of the ignition once it was turned that looked perfect.
lil_Blue_Ford
6,101
Butler, PA, USSA
4.9L
Ok, I’m tight on time right now, but I’ll try to hit a couple points real quick.
When I got my latest Ranger, I got one key with the truck, PATS of course. I asked the local dealership and was quoted $110 to program up to 8 keys plus the keys. The local locksmith wanted $40 a key and $65 per key to program. I went looking for another option.
Found a locksmith who I could send a high definition picture of my key to, he would work out the code, cut a chip key and ship it to me for around $21. Price goes down a little if you get more keys because that’s counting shipping. Not exactly sure of his current prices since I’m now able to cut my own off of that key.
Still left me with programming. Got an adapter for my laptop and went to work finding a program to get me access. If that failed, I learned that the good snap-on scanners will get you in and I know people. Found my truck had three keys programmed but I only had one, so I dumped the memory and put my keys in. Now if one of those other keys would show up, they can unlock the door but not start the truck.
Sent from my kite using a trebuchet
Craig0320
225
Mississppi
Engine Type
V8
5.0
2WD / 4WD
Break it right the first time. Fix it better the next time.
You are right about that. My assistant is a retired 35 year locksmith. I had a 96 monte carlo gave to me and the key is missing. There is no key code on the cylinder. Someone soldered the correct resistor in for the vats and I can just use a regular key for the ignition. He is going to disassemble the lock itself and see what tumblers are in it and cut the key according.
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
